integra injectors help
Old Oct 12, 2007 | 04:12 AM
adamrich33's Avatar
Default integra injectors i need your help
i got a 91 teg with a b18b motor, so my question is should i leave or bypass the injector resistor box that worked on the older lower impedence injectors, ive been experiencing horrible gas mileage and i think this is the culpret. so what do you all recommend, i did temporaliy bypass the box and the car will run that way.
Modified by adamrich33 at 12:46 PM 10/12/2007
Modified by adamrich33 at 5:46 PM 10/13/2007
Old Oct 12, 2007 | 11:45 AM
adamrich33's Avatar
Default Re: integra injectors help (adamrich33)
bump
Old Oct 13, 2007 | 04:47 PM
adamrich33's Avatar
Default Re: integra injectors i need your help (adamrich33)
whats the deal can any one help, maybe i should ask a retarded question like what kind of oil to use
Old Oct 13, 2007 | 06:24 PM
SleeperGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrich33 &raquo;</TD></TR><TR><TD CLASS="quote">whats the deal can any one help, maybe i should ask a retarded question like what kind of oil to use</TD></TR></TABLE>
can't help you with your question but i feel your pain.
Old Oct 14, 2007 | 02:00 PM
adamrich33's Avatar
Default Re: integra injectors i need your help (SleeperGSR)
thanks anyways sleepergsr
ttt
Old Oct 14, 2007 | 02:21 PM
doood's Avatar
been there done that
if you currently have low impedence injectors leave the resistor boxes. your gas mileage problem is from something else.
Old Oct 15, 2007 | 03:58 AM
adamrich33's Avatar
Default Re: integra injectors i need your help (doood)
i have injectors that came with the motor i bought out of a 98 ls teg
Old Oct 15, 2007 | 07:57 AM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrich33 &raquo;</TD></TR><TR><TD CLASS="quote">i have injectors that came with the motor i bought out of a 98 ls teg</TD></TR></TABLE>
I assume you had to splice in the OBD2 harnesses too?
Remove the resistor box. Those are saturated injectors and they don't require it.
Old Oct 15, 2007 | 09:36 AM
adamrich33's Avatar
Default Re: integra injectors i need your help (Dartanian)
no i reused the obd0 harness on the b18b motor, i had to alter the plugs on the injectors and swap map sensor plugs, i went ahead and jumped out the resistor box and everything seems to be okay
LSej1
May 20, 2008 09:13 PM
THEDirtyDseriesWOOT
Mar 21, 2006 05:35 PM
turboH22Aakkord
Sep 20, 2005 07:50 AM
turbohf
Oct 18, 2004 02:34 PM
