Turbo GSR cutting out
I serve phở for my babies
This is the second turbo kit my friend has put on his car..
at around 7,000 rpm and 7,500 rpm it cuts out really bad and it won't let the motor rev higher.. we thought it was the plug gap but it turns out it wasn't.. the gap is at 0.032 right now and we started from a 0.038. and it doesn't feel any different
we know the motor is getting enough fuel because when we let off it has a nice backfire..
any suggestions or help would be appriciated
gap them at .028 and make sure you have good wires. if the plug wires are failing you are not prividing strong spark adn you are spark knocking. rotor button could be it too. just start checking everything in the ignition system. do you have a msd or anything on this car? you ned to check rotor, cap, plug wires, coil and ignitor. also is this car tuned???
i dont understand how you can even get on the motor with a basemap? when i had my basemap in before my tune the car wouldnt rev over 5500 and it didnt build any boost
Check your timing, it might be off. I had the same problem in my b16 turbo, and my timing was off and at high rpm's it will cut off just like your case
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HarfordCTR »</TD></TR><TR><TD CLASS="quote">why are you at 7500 rpm's on a basemap? U want to blow it up?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HarfordCTR »</TD></TR><TR><TD CLASS="quote">why are you at 7500 rpm's on a basemap? U want to blow it up?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HarfordCTR »</TD></TR><TR><TD CLASS="quote">why are you at 7500 rpm's on a basemap? U want to blow it up?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toekneexD »</TD></TR><TR><TD CLASS="quote">the car is on a s300 hondata base map.i think ill try to do the rotor bug first then wires after that.. thanks for input bump for more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu »</TD></TR><TR><TD CLASS="quote">
thats not the way you check air fuel...the car needs to be tuned
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>thats not the way you check air fuel...the car needs to be tuned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 »</TD></TR><TR><TD CLASS="quote">sounds like a timing issue, but could also be a map problem what map and setup are you useing?</TD></TR></TABLE>
b16 with greddy turbo kit, the motor has more then enough fuel. and i believe the basemap is better then a FMU..
we ran the same map on a previous boost setup and it worked flawless to 8 grand. now we can't seem to get past 7,500... we'll double check all the ignition this weekend.. thanks for the bump guys!
we ran the same map on a previous boost setup and it worked flawless to 8 grand. now we can't seem to get past 7,500... we'll double check all the ignition this weekend.. thanks for the bump guys!</TD></TR></TABLE>
having more then enough fuel is also a problem. the car isnt tuned. you dont know what the air fuel is you dont know what the ignition timing is. you should really check these major things before you ask for help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">
having more then enough fuel is also a problem. the car isnt tuned. you dont know what the air fuel is you dont know what the ignition timing is. you should really check these major things before you ask for help</TD></TR></TABLE>
so we hooked up a wideband and the a/f is 11:5-12:5 from vtec all the way up to 7,500. then it cuts out. after tightning the gap down the 0.030 it didn't even seen to help. what other things could be the problem? it's not the rotor bug, cuz we replaced it
well i got the car tuned. and the car continued to do it.. today i got my exhaust(apexi ws2 piping w/ s2k exhaust) completely on (car was open downpipe before) and now it doesnt cut out anymore. any reason?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toekneexD »</TD></TR><TR><TD CLASS="quote">well i got the car tuned. and the car continued to do it.. today i got my exhaust(apexi ws2 piping w/ s2k exhaust) completely on (car was open downpipe before) and now it doesnt cut out anymore. any reason?</TD></TR></TABLE>
werd^^^.. i bet noone would've guessed that..
if you have exhaust dumping under the engine bay it will be pushed back up the firewall and be sucked into the motor.....if its open downpipe it needs to go pretty far back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">if you have exhaust dumping under the engine bay it will be pushed back up the firewall and be sucked into the motor.....if its open downpipe it needs to go pretty far back</TD></TR></TABLE>
ooo. good point. cuz alot of the smoke got inside the car when it was windy out
egsicxxx
Feb 3, 2013 09:15 AM
