melted secondary o2 sensor wires?
Old Oct 11, 2007 | 04:55 PM
btbomb's Avatar
Default melted secondary o2 sensor wires?
will the ecu fuse blow if maybe the secondary o2 sensor wires melted from a huge exhaust leak right at the cat?
Old Oct 11, 2007 | 06:32 PM
slowcivic2k's Avatar
Default Re: melted secondary o2 sensor wires? (btbomb)
Possibly, but more likely your ALT/SP SENSOR fuse will blow, alternator will not charge, and you will have codes for the VSS, O2, MAP, TPS, and depending on the car, the IACV.
That scenario covers all the wires touching each other, and then grounding out.
Old Oct 11, 2007 | 06:36 PM
forcefedferio's Avatar
Default Re: melted secondary o2 sensor wires? (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">Possibly, but more likely your ALT/SP SENSOR fuse will blow, alternator will not charge, and you will have codes for the VSS, O2, MAP, TPS, and depending on the car, the IACV.
That scenario covers all the wires touching each other, and then grounding out.</TD></TR></TABLE>
don't forget the IAT...damn green/black ground wire.
Old Oct 12, 2007 | 06:16 AM
btbomb's Avatar
Default Re: melted secondary o2 sensor wires? (forcefedferio)
all those are fine, think its just a bad main relay?
Old Oct 12, 2007 | 06:26 AM
btbomb's Avatar
also my CEL is constantly on even if i reset the battery
i use a 30a fuse to just see if i can turn it over, the fuse doesnt blow, but the car won't start
Old Oct 13, 2007 | 12:14 PM
Do yourself a favor and read the warning on your fuse panel. Putting 30A of current into a 20gauge wire will easily melt it, and cause even more problems. If the fuse blew, it blew for a reason. If you want to fry the components, by all means then put an 80A in there and watch your car start on fire.
Might want to start off by telling us what you did prior to this happening, and what your CEL is for.
EKjdmCTR
May 5, 2007 11:22 PM
bboysakeq4
Jan 18, 2007 06:45 PM
SpoolinEK
May 21, 2004 02:42 PM
Spudddy
Aug 3, 2003 05:36 PM
SIckH22Atch
May 8, 2003 09:49 AM
