O2 sensor voltages....
Old May 6, 2003 | 09:46 AM
SIckH22Atch's Avatar
Default O2 sensor voltages....
ok, so here is the deal... I got a new O2 sensor because I had a heated o2 sensor cel, but when I put the new o2 sensor in, it would blow the ecu fuse. So I think when I was extending the wires for the o2 sensor I mis-matched one or something. so I just need to know what the voltages should be for the 4 wire o2 so I can just connect the correct wires. Thanks!
Old May 6, 2003 | 12:48 PM
prelittlelude's Avatar
Default Re: O2 sensor voltages.... (SIckH22Atch)
your gonna be hard pressed to find that kind of specific answer in here, my first question would be why did you have to cut/ extend any of the wires, i would start there and make sure you did it right. i had to replace my O2 sensor when i put my header in. i bought mine from nopionline. just compare your old one with your new one, if your blowing a fuse and had a problem with the original 02 circuit then i would check all your wires might be more complicated than just a bad sensor and make sure you got the right replacement sensor
Old May 7, 2003 | 07:37 PM
Default Re: O2 sensor voltages.... (prelittlelude)
sorry about not giving all the info... I have a 93 JDM H22a in my civic hatch, so I had to switch the connector and extend the wires. everything else is fine in the swap, just one stupid o2 sensor issue.
Old May 8, 2003 | 06:20 AM
if you you did a swap into a civic you need to use the 02 sesor that has the correct connector in the first place. i think thats why your cooking your fuse. triple check your wiring, and worst case buy a stock snesor for what ever ecu your using
Old May 8, 2003 | 09:49 AM
577HondaPrelude's Avatar
you porb. know this but the 4 wires are:
1 +12v (heater)
2 gnd (heater)
3 O2 Signal out
4 gnd (signal)
sorry I can't tell ya what collor each wire is
Markadler47@gma
Mar 22, 2019 02:36 PM
Nataku
Jul 3, 2008 09:44 PM
h22dxhatch
Jul 28, 2007 01:03 PM
01blackgsr
Jun 24, 2006 06:23 PM
