problems with b20 in 96 civic
Old Oct 11, 2007 | 04:35 PM
slambedcivic's Avatar
Default problems with b20 in 96 civic
1996 civic lx
OBD2 JDM B20B
running civic wiring harness
running obd1 ITM w/ obd1 injectors and clips.
problem 1. IACV from 96 civic d series had three wires. LS ITM has 2. I cut and spliced (soldier and tape) the + and the - to the proper positions on the IACV since i have a honda service manual was this correct or is there something else i should do with the three wires to the 2 wire sensor?
Problem 2. Obviously the D16 had a Crank position sensor. and apparently the obd2a ls computer is also calling for one. hense the CEL listed below. what do i do about this?
im also getting 2 CEL codes. Ive gotta actron code reader and the codes are as follows.
- P1508 Idle Air Control Valve Circuit Failure (Acura) obviously from above problem
- P1337 Crankshaft Speed Fluctuation Sensor No Signal (Acura)
Old Oct 11, 2007 | 08:11 PM
90datech's Avatar
Default Re: problems with b20 in 96 civic (slambedcivic)
yo for the CKF p1337 code you should be able to do this.
http://technet.ff-squad.com/ckftrick.htm
Old Oct 11, 2007 | 08:41 PM
Default Re: problems with b20 in 96 civic (90datech)
much appreciation bro. never thought ide see the day when youre helping me with hondas.
Old Oct 12, 2007 | 06:35 AM
90datech's Avatar
yeah... i figured i give you a hand
Old Oct 12, 2007 | 03:24 PM
still need help
Old Oct 12, 2007 | 05:11 PM
up for IACV help
Old Oct 12, 2007 | 09:08 PM
90datech's Avatar
here yo look at these and see if you find what you need, i would of help you out more but its one of them nights and i got a swap to do tomorrow....good luck
http://www.phearable.net/tech/...2.jpg
Old Oct 13, 2007 | 09:51 AM
where the hell were you 7 years ago when i started into this ****. you should have been in it instead of messing with those mazda pieces of crap.
Old Oct 13, 2007 | 08:00 PM
90datech's Avatar
yeah i know, but im here now.. hit me up if you need any help
Old Oct 13, 2007 | 11:27 PM
thanks man! how things go today with the EK?
Old Oct 15, 2007 | 06:03 AM
90datech's Avatar
we need a rear si L tranny bracket, and the si driver side mount on the motor.
Old Oct 15, 2007 | 06:47 AM
ive got the rear one. 75 bucks
Old Oct 21, 2007 | 02:04 PM
MeetyourconnecT's Avatar
B20 is serious but you gotta get that block all done up! LS block all day!
Old Oct 21, 2007 | 07:54 PM
Default Re: (MeetyourconnecT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeetyourconnecT &raquo;</TD></TR><TR><TD CLASS="quote">B20 is serious but you gotta get that block all done up! LS block all day!</TD></TR></TABLE>
thanks for the help jackass
Old Oct 22, 2007 | 04:17 PM
Default Re: (slambedcivic)
No beef dude just trying to get my posts up. My boy did a b20 w/ b16 head and learned the hard way. Just trying to put my two sense in whether or not it was needed
Old Oct 22, 2007 | 07:21 PM
ltrkstr2k's Avatar
Default Re:
did you ever get that straight jason
Old Oct 22, 2007 | 08:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeetyourconnecT &raquo;</TD></TR><TR><TD CLASS="quote">No beef dude just trying to get my posts up. My boy did a b20 w/ b16 head and learned the hard way. Just trying to put my two sense in whether or not it was needed </TD></TR></TABLE>
first off if you have nothing to contribute but senseless posts (aka. postwhoring) to get your posts up, then you need not be here taking up bandwidth.
what did he learn the hard way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ltrkstr2k &raquo;</TD></TR><TR><TD CLASS="quote">did you ever get that straight jason</TD></TR></TABLE>
im really tired of messing with this customer really. will be taking care of it shortly. did you get the driverside mount you needed?
Old Oct 22, 2007 | 08:19 PM
Ek9kidd's Avatar
1st. whats your plans for this b20 motor? boosting? sure they are good for boost but in this case they have thinner sleeves. What i would recomend is get an LS block and put the b20 head on. It lowers compression more esp if you have a thicker headgasket (i think im right, cant remember) otherwise if you plan on just boosting the B20 block run lost boost. As for by passing the crank positioning sensor. Do it, it works...just did it for my LS motor and its a hell of alot cheaper than paying the $200 for the sensor...mayb more.
Old Oct 23, 2007 | 02:27 PM
Default Re: (Ek9kidd)
this is a customers car. im going to be doing the wiring tonight as it is about 60 miles from my house. ill keep everyone posted
Old Oct 23, 2007 | 06:38 PM
All truth to the contrary there is no such thing as a jbm b20b, thats a usdm motor. All I ever came across was a b20b long block usdm spec. Even if there is a jdm b20b, Im sure it's compression is rated the same as a usdm spec.
My boy had a 99' usdm b20b longblock(9.6 compression) with a b16 head and all though it pulled hard the sleeves just crumbled after a month or so. That block isnt made for beating on, thats the only reason why I called upon the LS block for duty. Im not sure what the final compression was once the b16 head was thrown on.
Taking up bandwith=.......slap...
Old Oct 27, 2007 | 04:57 AM
truth be told there is no such thing as a USDM B20B.... all usdm motors have a 5 digit alpha-numeric engine code.
billard
Mar 22, 2011 06:59 PM
H_civic_H
18
Dec 2, 2010 09:53 PM
hatchback freek
Mar 4, 2008 03:49 AM
WhiteEkCivic
Oct 19, 2007 01:02 PM
Flamenco-T
Sep 8, 2002 12:05 PM
