honda civic problems
i have a honda civic sedan ( 96 with a jdm b18b) i have been working on this expletiveen thing for about a year now and nothing is going right . i baught an engine harenss from honda, its fit for a 96 civic ex sedan. but the problem is it only has one oxygen sensor plug, its for the primany heated oxygen senser, but with a new oxygen sensor it still throws me the code. my motor is obd1, and i was planning to run an obd2 computer on it, i ran my stock ecu form my d16y7 amd i works fine, the only porblem is it throws my IAC and the two oxygen sensers. i need a 96 integra ecu (ls) and need a new engine harness. what do you guys think, my old one is shot and has cut wires, and the new one is a peace of ****, and to top it off i dont think i can return it because i cut the injector plugs to put in the obd1 plugs in, what should i do i allready put 4500 in to this ****. thanks for your help
Re: honda civic problems (aznboyhoy)
price of car 350
price of engine 1750
price of engine parts (intake header fuel pump, exhaust system, fuel presure regulator, cross drilled sloted rotors, crower cams, buddy club camgears, . 2000
price of gengine mouts 270
Re: honda civic problems (hatchback freek)
Okay, I misunderstood you, i thought you were saying that you put that much just into trying to get it to run.
Re: honda civic problems (96civic_hb)
i called the dealer and thay said i have to repin the down stream oxygen sensor right in to the ecu and i did, still no results.
slambedcivic
20
10-27-2007 04:57 AM
CSHornet60
10
06-16-2006 07:17 AM
