oil on spark plug
Old Oct 11, 2007 | 01:42 PM
thegooddoctorceretti's Avatar
Default oil on spark plug
i have oil on my #4 sparkplug whats wrong?
Old Oct 11, 2007 | 01:44 PM
wiZCo's Avatar
Stouts 'n' Scotch
Is it on the electrode side or the ceramic side? Is there oil in the spark plug tube as well?
Old Oct 11, 2007 | 01:50 PM
Default Re: (wiZCo)
driver side, oil all over spark plug chamber, and coating the plug pretty well. no other liquids draining though
Old Oct 11, 2007 | 01:53 PM
wiZCo's Avatar
Stouts 'n' Scotch
Is the tube seal in bad condition? It's the rubber grommet that's on the underside of the valve cover. That's the most common cause of leaks in the tubes, otherwise, it's a rocker arm o-ring.
Try replacing the spark plug tube seals and see if that does the trick.
Old Oct 11, 2007 | 01:54 PM
Duane_in_Japan's Avatar
Default Re: (thegooddoctorceretti)
You need a complete valve cover gasket kit, VC gasket, nut and bolt rubber washers, 4 spark plug well gaskets. Also replace the PCV Valve and hose, its good insurance.
EDIT
YOu also may want to think about changing your plug wires, but that one may clean up just fine, so clean it good.
Old Oct 11, 2007 | 01:56 PM
Default Re: (Duane_in_Japan)
plug wire is good, no oil touched it.
Old Oct 11, 2007 | 02:07 PM
jdm_titan's Avatar
Default Re: oil on spark plug (thegooddoctorceretti)
u need a Valve cover gasket and not a AVT liquid gasket. cause if not the leak will continue
Old Oct 11, 2007 | 02:09 PM
Default Re: oil on spark plug (jdm_titan)
ok good, i cant fix it til saturday, should i prolong drin=ving it. or is it ok til then
Old Oct 11, 2007 | 02:29 PM
wiZCo's Avatar
Stouts 'n' Scotch
Unless it's swimming in oil, you should be OK for two more days.
Old Oct 11, 2007 | 02:50 PM
janz3n's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Is the tube seal in bad condition? It's the rubber grommet that's on the underside of the valve cover. That's the most common cause of leaks in the tubes, otherwise, it's a rocker arm o-ring.
Try replacing the spark plug tube seals and see if that does the trick.</TD></TR></TABLE>
listen to this guy, rocker arm o-ring is also a common problem.. iv had this problem twice before i put a japanese engine in my car. but ya like everyone has said try replacing the VC gasket first. if not either replace the rocker arm o-ring yourself or spend tons of money getting a shop to do it for you..... or replace that engine......lol
rjmancia
15
Sep 13, 2008 08:57 AM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
civicxspower
Jun 5, 2005 04:12 PM
Saki
Mar 4, 2005 06:20 PM
vimsen
Nov 1, 2003 02:37 PM
