Finished my D series manifold
Old Oct 10, 2007 | 09:28 PM
55superbeetle's Avatar
Default Finished my D series manifold
Finally finished it up tonight. Fit's in my ef with full size radiator.
Does anybody know if the Tial wastegate clamps will fit my gay obx wastegate ??
Old Oct 10, 2007 | 09:43 PM
.adam.'s Avatar
not sure on the wastegate, but its lookin good!!
Old Oct 11, 2007 | 02:57 AM
CSaddict's Avatar
Default Re: (.adam.)
Set your boost cut and you will be fine.
Old Oct 11, 2007 | 08:19 AM
.:Swig:.'s Avatar
Default Re: Finished my D series manifold (55superbeetle)
looks pretty nice.. lets see how it does
Old Oct 11, 2007 | 11:09 AM
the_unknown's Avatar
GDD Lonely Krew
all that nice work and you have an obx wastegate? are you asking to blow your motor? i cant understand people who skimp on such vital parts of an engine assembly. why not use foil in place of the main bearings? i hear the good ones can be spendy and foil should work fine..........
nice manifold btw
Old Oct 11, 2007 | 01:19 PM
93supercoupe's Avatar
Default Re: (the_unknown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_unknown &raquo;</TD></TR><TR><TD CLASS="quote">all that nice work and you have an obx wastegate? are you asking to blow your motor? i cant understand people who skimp on such vital parts of an engine assembly. why not use foil in place of the main bearings? i hear the good ones can be spendy and foil should work fine..........
nice manifold btw</TD></TR></TABLE>
Boost cut among other things will protect him from this "shitty" wastegate.
Old Oct 11, 2007 | 02:04 PM
FastCougar's Avatar
Default Re: (93supercoupe)
Clean your oil pan
Old Oct 11, 2007 | 03:54 PM
HiProfile's Avatar
Is that just oridinary SS flex tube for the WG flexpipe? I was told that was impossible to weld, so I never bought any. I was able to find very cheap ss flex, but its 1.75ID, and still more $$ than just ss flex tube.
BTW as long as the WG's valve shaft and seal are smooth and seal well, and you don't rip the diaphragm, it will work just fine. Boost creep is mainly from a leaking valvestem in the WG, and obviously a torn diaphragm won't work...
Old Oct 11, 2007 | 06:01 PM
rob...'s Avatar
Default Re: Finished my D series manifold (HiProfile)
is there a huge crack in your block?
Old Oct 11, 2007 | 06:13 PM
*Boostwerks*'s Avatar
Default Re: Finished my D series manifold (rob...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob... &raquo;</TD></TR><TR><TD CLASS="quote">is there a huge crack in your block?
99.987% thats a fab motor
Looks great! I love EF's with nice well built yet modest turbo setups.
Old Oct 11, 2007 | 06:52 PM
Default Re: Finished my D series manifold (Boostwerks.com)
Thanks for all the comments guys.
Yep that is a huge hole in the block and yes it is just used to mock up manifolds.
I know im taking a chance with the wastegate but i have used 5 of them so far and none of them have failed yet. Just tore them down an reassembled with loctite . I use the car for track days and the hundred horses just aint cuttin it anymore. Hopefully this setup will get me 200 wheel which should make it a hell of alot more fun.
The flex piece is just a piece i got at autozone and yes it was a bith to weld. It was hard not to just blow thru the thin flex piece. Do u guys know where i can get the stainless version of this stuff?
And as for the whole cheap wasteate is like using foil for main bearings speech..... seriously, just stop
Old Oct 14, 2007 | 10:20 AM
xci_ed6's Avatar
only thing I would change would be to merge the wg dump into the down pipe farther from the turbo. It looks like there is space for them to run side by side under the oil pan, so maybe as far as the exhaust flange.
Old Oct 15, 2007 | 09:14 AM
90dxhmt's Avatar
Default Re: (xci_ed6)
Wow looks great and I use the same wastegate works great!
Old Oct 15, 2007 | 09:24 AM
B20luda's Avatar
Default Re: (90dxhmt)
looks more like a hole than a crack...
Old Oct 16, 2007 | 09:09 PM
EFbomb's Avatar
nice job
where did you source the materials ?
Hybrid96EK
Sep 17, 2009 03:01 AM
dmotoguy
Welding / Fabrication
19
Aug 20, 2008 07:39 PM
B16Civic93
Sep 28, 2005 11:37 AM
CaptainMorgan
Jan 19, 2004 03:49 AM
Full-Race Geoff
Jun 27, 2002 01:08 PM
