Clutch Master Cylinder?
Old Oct 10, 2007 | 09:16 PM
jaywo_23's Avatar
Default Clutch Master Cylinder?
I have a problem with my clutch and i think it's my clutch master cylinder. When i push in my clutch it doesn't go in smooth. There is a bunch of clicks and it feels like a dirty mouse ball. The clicks prevented the clutch from coming back up again. I've bleed the system and that hasn't worked. If anyone know what this is please help me.
Thanks,
Jason
Old Oct 10, 2007 | 10:01 PM
DOHC4banger's Avatar
Default Re: Clutch Master Cylinder? (jaywo_23)
ive seen this problem before
check to see if your master or slave cylinder is leaking or any of the clutch lines
my guess is that if you replace the master and slave cylinder youll be good to go
Old Oct 11, 2007 | 12:05 PM
Blk00EJ8's Avatar
How many miles on the clutch? Sounds like a bad pressure plate..?
Old Oct 11, 2007 | 04:41 PM
JimBlake's Avatar
Default Re: Clutch Master Cylinder? (Blk00EJ8)
If it's a bad pressure plate you'll have to pull the tranny out.
Before doing that, check under the dash to rule out bad pivot bushings on the pedal itself.
Old Oct 11, 2007 | 08:49 PM
Blk00EJ8's Avatar
Default Re: Clutch Master Cylinder? (JimBlake)
I say either the pressure plate or the release fork/bearing are binding or damaged. Regardless, check the easy things first, because anything I've listed requires you to pull the tranny. fun...
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
92eg6lsvtec
Jun 5, 2006 08:43 AM
T"u"Rtle
Apr 21, 2006 10:17 AM
anewfoundkevin
Sep 2, 2004 04:56 PM
Pandahatch
12
Aug 24, 2004 07:48 AM
