How To Make Gauges Light Up
You have to pull out/or cut the 2 power wires from the connector that connects to the guage cluster and connect those to the lil black box that came with your guages. I say to cut the wires and not tap into them because having the cluster lights AND the indiglo guages lit up at the same time looks like crap. I did this like 5 years ago so I dont remember exactly which 2 wires were the light wires. Maybe someone could post a diagram.
C4 yellow wire Positive (fuse 25) or you could just use a spade terminal and slide it under the positive marked screw for the tach or speedo both options work for power.
For illumination connect to the C13 Red/Black wire, this the positive for illumination but the cluster uses a ground controlled negative for dimming...
pick up a haynes manual and look at the wiring digrams thats what i used when i put in my o/p and o/t and i just wired mine to the radio lights and they come on when the radio does (there mounted right under the radio so it was the closest place)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegod »</TD></TR><TR><TD CLASS="quote">thanx. it sound like u know what ur doing. i hope</TD></TR></TABLE>
Well I figure if my buddy with a turbo'd integra trusts me to install his new gauges and wire them up, as well as most of my friends come to me with any form of electronics questions or installations, I thing I know what I'm doing
Honestly tho, on my buddies integra this is how I did the wiring for his gauges and the tach that was in my car before I got an EX cluster was drawing power from the gauges in the same fashion I mentioned above... And I'm using the same set up for my gauges (but I'm getting light power from the hvac since my gauges are where my stereo used to be).
Tuesdaynightfever
May 10, 2005 12:45 PM
