best ecu for b16a2
Old Oct 9, 2007 | 05:07 PM
tigueremalo's Avatar
Default best ecu for b16a2
ok so am swaping a 2000 b16a2 into my hatch whats the best ecu for it that i can get at a junkyard or sumthing because they say that p28 is good but think about it the ecu redline is 7ish right when you can make mor power till 8000rpms?
Old Oct 9, 2007 | 05:09 PM
sicones's Avatar
Default Re: best ecu for b16a2 (tigueremalo)
the 99-00 B16A2 ecu, P2T
Old Oct 9, 2007 | 05:11 PM
EJ1chevelle's Avatar
chipped p28 is the way to go if its obd1. for making the redline at 8200k for stock b16 when it is chipped the b16 basemap will be used and it will automatically fix and move things up... also if you get it tuned you can get more detailed.
Old Oct 9, 2007 | 05:26 PM
Default Re: best ecu for b16a2 (93egB16A)
damn how much would it be to put a chip on it
Old Oct 9, 2007 | 06:04 PM
ummm i got my ecu chipped for $80.... it shouldnt be any more than $100 at a good shop.
Old Oct 9, 2007 | 06:17 PM
Ex-Eg-Driver's Avatar
stock
Old Oct 9, 2007 | 06:53 PM
em1_fox's Avatar
Default Re: (JayKayNidas)
u can get a p28 ecu..its pretty good..i reved my to 8500 rpms..or u can get shunk 2..
Old Oct 9, 2007 | 06:57 PM
sicones's Avatar
Default Re: (em1_fox)
if you use the proper ECU P2T, its way cheaper, can be had for ~$50, no conversion harness needed, and you will pass emissions
or you can spend $200+ on a chipped P28 that will make you run filthy stinken rich
Old Oct 9, 2007 | 08:18 PM
doood's Avatar
been there done that
Default Re: (sicones)
stock motor = stock ecu
simple concept really
tubed-ef
May 2, 2007 11:35 AM
Revolution2zz
Aug 10, 2006 07:52 AM
JDM B16A
11
May 21, 2006 04:21 PM
SL_RICK83
Mar 5, 2006 07:46 PM
