vtec pressure switch bypass obd2a??
Old Oct 9, 2007 | 03:17 PM
VegasHB's Avatar
Default vtec pressure switch bypass obd2a??
Got a 97 JDM GSR motor and noticed it doesn't have the vtec pressure switch so I was doing some searching but all I can find is bypassing it for OBD1 ECU's. I'm running a USDM P72 so I'm not sure how to bypass it. All I found was to bridge A4 & D6 but that's on an OBD1 ECU.
So for an OBD2a would I jump A8 and D15 then ground the black wire off the connector?
Old Oct 9, 2007 | 06:42 PM
VegasHB's Avatar
Default Re: vtec pressure switch bypass obd2a?? (VegasHB)
bump for info
Old Oct 9, 2007 | 06:52 PM
confidence's Avatar
you jump 2 wires together on the harness. i don't remember which ones right now.
if you search for VTP fix on pgmfi.org you will find it. this is why way i did my last one
Old Oct 9, 2007 | 07:50 PM
VegasHB's Avatar
Default Re: vtec pressure switch bypass obd2a?? (confidence)
Awesome, much cleaner fix than jumping more wires on my harness.
Thank you!!
br8crumb
Feb 16, 2015 06:58 AM
roadracer321
Jun 7, 2006 07:48 PM
iNERtIA
Apr 3, 2006 09:42 PM
ek9vboi2
Jun 24, 2005 07:44 PM
crvtt96
Jun 26, 2004 06:29 PM
