throttle sticking issues.. please help
Old Oct 9, 2007 | 01:42 PM
shabam's Avatar
Default throttle sticking issues.. please help
i am having throttle sticking problems. the first couple minutes of driving its fine. then if i leave the throttle at a certain position for like more than 2 minutes like when i'm cruising on the freeway then let off rpm goes does really slowly and stays at 2000ish rpm.. and if i stab the throttle and let go really fast, it goes away the rolling goes back to the regular 1200ish. if i don't stab the throttle and just let it stick at 2000 and come to a stop, it would also drop to normal. sometimes the idle surges too but thats pretty rare. i have tried everything from cleaning the throttle plate, lubricating and cleaning the **** out of the butterfly/spring thing, loosening and tightening the throttle cable to give or take away slack, and lubricating the cable. it is a brand new type r throttle cable. the throttlebody is a bbk 70mm. this problem popped out of no where, it never use to do it.
Old Oct 9, 2007 | 01:46 PM
circuitEG6's Avatar
Default Re: throttle sticking issues.. please help (shabam)
just a question...does it happen to be a skunk2 TB??
Old Oct 9, 2007 | 04:25 PM
shabam's Avatar
no its a bbk tb.
Old Oct 10, 2007 | 05:05 PM
circuitEG6's Avatar
Default Re: (shabam)
from what ive been told most aftermarket tb's are most likely going to have a sticky feel to them, not sure y no one ever explained that part to me but thats what im told, never owned an aftermarket tb before...
Old Oct 10, 2007 | 05:09 PM
Luserkid's Avatar
Default Re: throttle sticking issues.. please help (circuitEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by circuitEG6 &raquo;</TD></TR><TR><TD CLASS="quote">just a question...does it happen to be a skunk2 TB??
lol... i thought the same thing. There old 68mm was crap (dont know about the new ones).
What some people have done is take some sand paper to the throttle body where the butterfly meets the TB hole. Usually theres a defect in the casting that causes sticking when dirt is built up.
Old Oct 10, 2007 | 05:15 PM
circuitEG6's Avatar
Default Re: throttle sticking issues.. please help (Luserkid)
yea it was my buddy "had" it on his gsr and that **** stuck like a mother!! lol it was bad!
Old Oct 10, 2007 | 05:16 PM
circuitEG6's Avatar
sand paper idea sounds good i never thought of that!
Old Mar 13, 2008 | 11:00 AM
shortlid's Avatar
Well we have a bone stock '99 EX sedan 5-speed and the stock Throdle body stciks all the time! Has for about 30,000 miles. I clean it and lube it with deep creep. You guys think a new throdle cable at 120,000 miles might help?? It scares my wife when it sticks
Old Mar 13, 2008 | 11:11 AM
ATRekh2's Avatar
could it be the pedal in any way?? is that fine?
Old Mar 13, 2008 | 11:14 AM
BuCU's Avatar
Default Re: (ATRekh2)
I had a problem and still to this day...just need to get a new throttle body. The throttle plate is sticking on the sides of the body. We tried sanding down the inside a lil, adjusting everything and once in a while when you smash the gas and let go, it will stay in the close position tight. Have to hit the throttle hard to make it come loose.
Old Mar 13, 2008 | 01:04 PM
v8killaz's Avatar
Default Re: throttle sticking issues.. please help (shortlid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortlid &raquo;</TD></TR><TR><TD CLASS="quote">Well we have a bone stock '99 EX sedan 5-speed and the stock Throdle body stciks all the time! Has for about 30,000 miles. I clean it and lube it with deep creep. You guys think a new throdle cable at 120,000 miles might help?? It scares my wife when it sticks </TD></TR></TABLE>
mine did the same 96 civic ex gets stock and rpm stayed at 2000 when I'm on the highway in neutral I'd just buy a oem tb
Old Mar 13, 2008 | 01:05 PM
shortlid's Avatar
Default Re: (BuCU)
How much is a TB going to run me!!! Maybe I can hone it out with my Dremel tool. Is it just the butterfly too big for the throat of the TB?
Old Mar 13, 2008 | 02:11 PM
v8killaz's Avatar
Default Re: (shortlid)
trust me u don't want to do that cuz all the sensors control idle and any improper reading is going to just ruin ur idle, get one from the junk yard and clean it with throttle body cleaner real good, I got mine with all the sensors for 50$
Old Mar 13, 2008 | 02:21 PM
circuitEG6's Avatar
Default Re: (v8killaz)
just try taking a rag to it and cleaning it with some shop solvent...the older accords had that issue also (im a tech for honda) just work the butterfly open and closed as you clean it and then try it out...let me know what happens...
Old Mar 14, 2008 | 12:17 PM
shortlid's Avatar
Default Re: (circuitEG6)
Just use TB cleaner or Seafoams Deep Creep better?
shabam
Dec 9, 2007 07:52 PM
shabam
Oct 9, 2007 05:10 PM
shabam
Oct 9, 2007 02:20 PM
theresyourproblem
Oct 4, 2007 09:28 AM
Nameless Warrior
Feb 1, 2007 08:58 AM
