throttle sticking problems.. please help
Old Oct 9, 2007 | 01:41 PM
shabam's Avatar
Default throttle sticking problems.. please help
i am having throttle sticking problems. the first couple minutes of driving its fine. then if i leave the throttle at a certain position for like more than 2 minutes like when i'm cruising on the freeway then let off rpm goes does really slowly and stays at 2000ish rpm.. and if i stab the throttle and let go really fast, it goes away the rolling goes back to the regular 1200ish. if i don't stab the throttle and just let it stick at 2000 and come to a stop, it would also drop to normal. sometimes the idle surges too but thats pretty rare. i have tried everything from cleaning the throttle plate, lubricating and cleaning the **** out of the butterfly/spring thing, loosening and tightening the throttle cable to give or take away slack, and lubricating the cable. it is a brand new type r throttle cable. the throttlebody is a bbk 70mm. this problem popped out of no where, it never use to do it.
Old Dec 9, 2007 | 07:52 PM
pinks11's Avatar
Default Re: throttle sticking problems.. please help (shabam)
I have the same problem... i was going to change out the throttle body, but just ended up ******* up the other one, so im still stuck with the original one. I am considering changing the butterfly/spring thing. Any help??!?!? its for a 91 si
shabam
14
Mar 14, 2008 12:17 PM
shabam
Oct 9, 2007 05:10 PM
shabam
Oct 9, 2007 02:20 PM
Nameless Warrior
Feb 1, 2007 08:58 AM
HATCHFREEK
Jun 13, 2003 12:47 PM
