weird idle
Old Jun 13, 2003 | 12:05 PM
HATCHFREEK's Avatar
Default weird idle
its a 93cx... with a 98 b18c1... car runs fine.. just sometimes ( most times) while stopped it revs from 1000 rpms to like 2500 rpms by its self.. dunno know what it could be! what do u guys suggest?
Old Jun 13, 2003 | 12:07 PM
94dxt's Avatar
Default Re: weird idle (HATCHFREEK)
iacv or ficv most likely
if it almost always occouring it may be a vacc. leak but if not always prolly not
Old Jun 13, 2003 | 12:47 PM
absolut b18's Avatar
same EXACT thing happaned to me. check where your throttle cable meets up with your throttle body. look at that little rubber boot covering your throttle cable right befor it enters the throttle body. Is it loose? does it move aroung eaisly? Mine was liike that. All i did was move that boot up a little (away from the throttle body) and force it to go over one of the thicker parts of the throttle cable so it doesnt move back and forth. What happens is i think that rubber boot get caught in the throttle body (the part that pulls your cable) and when it gets stuck it doesnt let your throttle cable fully retract into its resting state causing your rpm to rise whatever level. try that. iif its the same problem it should work.
integra_101
Jun 1, 2013 03:26 PM
BIGef
May 4, 2012 12:16 AM
EKSedAndy
Oct 10, 2007 01:09 PM
theresyourproblem
Oct 4, 2007 09:28 AM
supracrx
Jan 7, 2007 08:06 PM
