why does it do this??
Old Oct 8, 2007 | 10:00 AM
90jdmsedan's Avatar
Default why does it do this??
i have a 1990 ef sedan and when i start the car up it like spits and sputter for like 10-15 mins everytime i start it have any answer let me kno thanx
Old Oct 8, 2007 | 10:01 AM
wiZCo's Avatar
Stouts 'n' Scotch
Do you have any check engine lights? Does it only idle rough when it's initially started up i.e. does it go away eventually?
Old Oct 8, 2007 | 10:30 AM
The_Undertaker's Avatar
75.168.105.221
Spits and sputters. You running open headers or there is a flange not bolted up.
Old Oct 8, 2007 | 10:39 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (The_Undertaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Undertaker &raquo;</TD></TR><TR><TD CLASS="quote">Spits and sputters. You running open headers or there is a flange not bolted up.</TD></TR></TABLE>
I didn't know that Honda engines had two cylinder banks, thus necessitating the need for more than one header. God, I hate you. Don't listen to this guy OP.
Old Oct 8, 2007 | 11:08 AM
Tyte-S's Avatar
Default Re: (wiZCo)
LoL^^^ What do you mean it spits and sputters? does it have a rought idle? Is it running rich or lean? What mods do you have , if any?
Old Oct 8, 2007 | 11:20 AM
EL Vap133's Avatar
Default Re: why does it do this?? (90jdmsedan)
You could have a bad fuel injector. I had a similar problem on my 98 hatch. Replaced the fuel injector in question (threw a code 73) and no more sputtering at start up.
Old Oct 8, 2007 | 11:27 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: why does it do this?? (EL Vap133)
even if the engine light is not on make sure you check that computer. The check engine light in my lude does not work and it was throwin 2 codes. I could not figure out what was wrong with it cause the light was not on until i looked at the ecu.
Old Oct 8, 2007 | 12:16 PM
65stang90crx's Avatar
You dont have chocolate lollypops on your plug wires do you? Both me and my father-in-laws CRX did that from the oil settling into the cylinder after sitting. It caused my car to run hard for a couple minutes. Just a suggestion and easy to check.
Old Oct 8, 2007 | 05:44 PM
90jdmsedan's Avatar
i do have a check engine light on but thats becasue i dont have my soeed senor on yet it really only does it in the morning or when i let it sit for a couple hrs then start it again
Old Oct 8, 2007 | 05:46 PM
90jdmsedan's Avatar
Default Re: (wiZCo)
the check engine ligjht is on but because the speed senor isnt hooked up yet but it does it when i start it in the morngin and when i let it sit for a couple hrs like when im in school but it stop about 10 15 min l8r
playahwitgame
Jul 5, 2006 05:20 PM
CRXdan
Nov 19, 2005 09:34 AM
Qveon
Jun 23, 2005 10:47 PM
Touge Tuning
Jun 23, 2005 05:21 PM
vtec.dc2
Dec 25, 2004 03:33 PM
