Which bearings with reground crank?
Old Oct 7, 2007 | 07:47 AM
DanishR's Avatar
Default Which bearings with reground crank?
Hi
I have a crank that I bought used and it must have been reground because the journals are 54.74mm (2.1551").
The block, without any bearings in it, is 58.96mm to 58.98mm (2.3213", 2.3220")
ACL sells bearings that are .25mm undersize but if they are still "green" they wont give enough clearence. I used this thread: https://honda-tech.com/zerothread?id=715490
Does Honda or anyone else sell bearings that will work with this motor?
Old Oct 7, 2007 | 11:27 AM
doood's Avatar
been there done that
Default Re: Which bearings with reground crank? (DanishR)
getting a new crank would be your best option. i would never use a reground crank.
Old Oct 7, 2007 | 12:46 PM
DanishR's Avatar
Default Re: Which bearings with reground crank? (doood)
Castillo (I think they are spelled like that) made it, so I think the crank is ok.
Old Oct 7, 2007 | 03:21 PM
NJIN BUILDR's Avatar
Unless it was nitrided again i wouldn't use it.Nitriding is rarely done on a regrind because of the expense.If this isn't done the journals tend to wear quickly.Regrinds tend to crack if the radius on the journals is incorrect and doesn't blend nicely.Honda does not make undersize bearings because they do not recommend regrinding.Aftermarket (ACL,Clevite,Topline,King) bearings are your only choice.You will have to live with the clearance the undersize bearings give you.
Old Oct 7, 2007 | 07:41 PM
BBBJTCWSAAS's Avatar
Default Re: Which bearings with reground crank? (NJIN BUILDR)
call castillo and ask him i'm sure he knows what the deal is
gdrum
Apr 6, 2017 06:57 AM
hatchet_honda
Nov 6, 2009 08:26 AM
hondaeg8
May 1, 2005 12:15 AM
NetLogic
Dec 16, 2004 01:57 PM
S13 slide
Dec 2, 2002 05:54 PM
