test pipe =backpressure??
Old Oct 6, 2007 | 08:50 PM
Chewy[Ek]'s Avatar
Default test pipe =backpressure??
does a test pipe or a hollow out cat create back pressure??
Old Oct 6, 2007 | 09:14 PM
Acidcrakker's Avatar
Default Re: test pipe =backpressure?? (Chewy[Ek])
Depends on the size of the pipe. Test pipe is completle unrestrictive. And bad for the enviornment.
The green house affect, is a matter of opionon
Old Oct 6, 2007 | 09:18 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewy[Ek &raquo;</TD></TR><TR><TD CLASS="quote">]does a test pipe or a hollow out cat create back pressure??</TD></TR></TABLE>
Why would it?
Old Oct 6, 2007 | 10:17 PM
AaronW's Avatar
The point of hollowing out the cat or using a test pipe is so the air can flow more freely.
I see that as being the opposite of creating backpressure.
Old Oct 6, 2007 | 10:31 PM
bb_one's Avatar
Only if the inner diameter of the test pipe is smaller then the inner diameter of the collector.
Old Oct 7, 2007 | 05:03 PM
Chewy[Ek]'s Avatar
thanks for the responses
Old Oct 8, 2007 | 03:20 PM
Default Re: test pipe =backpressure?? (Hawkze_2.3)
Okay will this set-up create back pressure for me.
2 inch collector to 2.5 cat converter to 2.5 inch pipes to 2.25 muffler.
Reason Im asking is cause thats what my setup will be.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb_one &raquo;</TD></TR><TR><TD CLASS="quote">
Only if the inner diameter of the test pipe is smaller then the inner diameter of the collector.</TD></TR></TABLE>
Old Oct 8, 2007 | 04:06 PM
mattsnooz's Avatar
Default Re: test pipe =backpressure?? (Acidcrakker)
2 inch collector is kind of bottle necking the whole system. If those are inside diameters you should upgrade to a 2.5 inch diameter collector!
Old Oct 8, 2007 | 04:15 PM
Default Re: test pipe =backpressure?? (mattsnooz)
Okat say I go that route will the 2.25 muffler affect back pressure
loner714
Apr 13, 2007 01:50 PM
dc4teg95
38
Jan 15, 2007 01:35 PM
EG type GTR
Jul 9, 2006 05:28 PM
renegadez7o7
Sep 9, 2005 07:03 PM
