test pipe?
Old Apr 12, 2007 | 07:23 AM
loner714's Avatar
Default test pipe?
will a test pipe effect my gas mileage?
Old Apr 12, 2007 | 07:41 AM
JasonST's Avatar
Default Re: test pipe? (loner714)
Probly not, but it's illegal In the U.S. to run a test pipe, and it sounds raspy as heck, so I wouldn't run one if i were u. A high flow cat would be much better.
Old Apr 12, 2007 | 09:14 AM
VTEC_PRODUCTION's Avatar
Default Re: test pipe? (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Probly not, but it's illegal In the U.S. to run a test pipe, and it sounds raspy as heck, so I wouldn't run one if i were u. A high flow cat would be much better. </TD></TR></TABLE>
agreed...unless its absolutely important to you to have one...then do what you want mane...
Old Apr 12, 2007 | 10:11 AM
Wraith_G2IC's Avatar
You live in CA. This is just begging for trouble.
Test pipes are for "Off-Road Use Only".
Stock, or high-flow converter. End of story
Old Apr 12, 2007 | 10:16 AM
kuja396's Avatar
Default Re: test pipe? (Wraith_G2IC)
I'm running a test pipe... Absolutely no affect on sound, no affect on gas mileage. No problems besides passing emmisions. END OF STORY
Old Apr 12, 2007 | 10:45 AM
Default Re: test pipe? (kuja396)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja396 &raquo;</TD></TR><TR><TD CLASS="quote">I'm running a test pipe... Absolutely no affect on sound, no affect on gas mileage. No problems besides passing emmisions. END OF STORY </TD></TR></TABLE>
Carlos Mencia's favorite Dee Dee Dee has spoken.
Old Apr 12, 2007 | 11:03 AM
1.8L_allmotormilitia's Avatar
Actually when i was running a test pipe on my car with stock cat back it wasn't raspy unless the resonator was removed. But after i put my buddy club spec II on and yeah I don't know if the exhaust is designed to be raspy/loud or if the test pipe caused it. Also with test pipe installed it will give you top end power, but it will also give you LITTLE bad gas mileage, but nothing noticeable.
Edit: well i have bad gas mileage because I'm also running a ecu and some other mods.
Old Apr 12, 2007 | 11:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith_G2IC &raquo;</TD></TR><TR><TD CLASS="quote">You live in CA. This is just begging for trouble.
true, I live in California and yeah it smells like **** since my car is running rich and California is strict about having cats on your car.
But what can i do? I need more power.
Old Apr 12, 2007 | 11:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
BC Spec II is LOUD as F@*K no matter what pipes are on it, even with the silencer in there.
As somebody in the slammed thread said, the silencer only makes it go from stupid loud to just hella loud
Old Apr 12, 2007 | 12:07 PM
loner714's Avatar
the test pipe doesnt sound that bad. i have sri and a dc header. maybe its not that bad because i still have my stock exhaust. the smell aint that bad either. someone said it will smell like rotten eggs.
Old Apr 12, 2007 | 02:00 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">
But what can i do? I need more power. </TD></TR></TABLE>
and you think a test pipe is going to do it for you?
Old Apr 12, 2007 | 02:20 PM
yee SERIOUS's Avatar
a test pipe isn't gonna make any more power than a high flow cat. i would get a high flow cat because depending on the exhaust it can change the sound and it usually does stink.
Old Apr 12, 2007 | 02:59 PM
iH8RICERZ's Avatar
Default Re: (kidsafe yee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidsafe yee &raquo;</TD></TR><TR><TD CLASS="quote">a test pipe isn't gonna make any more power than a high flow cat. i would get a high flow cat because depending on the exhaust it can change the sound and it usually does stink.</TD></TR></TABLE>
exactly what I was going to say..... when I had a test pipe, the car's tone was a little deeper, but everytime you come to a stop light, or get out of your car....you end up smelling just like your car!
Old Apr 12, 2007 | 04:29 PM
Schister66's Avatar
Man U FTW
If you live in California, running a test pipe is great way to get into trouble....just get a high-flow cat or stick w/ what you have....
Old Apr 12, 2007 | 04:54 PM
Benhawk's Avatar
Default Re: (Schister66)
I am currently running a Megan 4-2-1 2pc header with a Skunk2 Test pipe, AEM V2 and a Apexi WS2 Cat back exhaust on a 95 LS, and it isn't any louder then having the cat in the mix, maybe a little bit of a deeper tone. I did notice a little bit of an impovement on power once I took the cat out, but not a lot. I will vouch for the smell, it dose stink once you remove the Cat, but I live in NH so I don't have to worry about emissions.
I bought the Skunk2 pipe from Evasive motor sports, they were the cheapest with shipping included in the price. I think it came to $113.
Old Apr 12, 2007 | 05:05 PM
bkmc24's Avatar
Default Re: (Benhawk)
Hell, even cheaper, go to advance auto, but a foot of 2.5 inch piping for like $2 and make one yourself. only problem being the bung for the O2 sensor
Old Apr 12, 2007 | 05:42 PM
ac_attak's Avatar
Default Re: (bkmc24)
to test pipes. Get a carsound cat.
Old Apr 12, 2007 | 05:53 PM
qwk db8's Avatar
just driving a lowerd honda is begging for trouble
Old Apr 12, 2007 | 07:35 PM
DC2*Integra's Avatar
Default Re: test pipe? (qwk db8)
what i did was buy a cheap aftermarket cat, empty out the inside and hammer in a test pipe in there.
Old Apr 12, 2007 | 07:43 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qwk db8 &raquo;</TD></TR><TR><TD CLASS="quote">
just driving a lowerd honda is begging for trouble</TD></TR></TABLE>
no, driving a dumped honda is begging for trouble
Old Apr 13, 2007 | 04:41 AM
Default Re: test pipe? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
no, driving a dumped honda is begging for trouble</TD></TR></TABLE>
what is a dumped honda?
Old Apr 13, 2007 | 05:12 AM
bkmc24's Avatar
Default Re: test pipe? (Acura_Integra_Type_R)
poop if NA
Nice if boosted
Old Apr 13, 2007 | 06:26 AM
DC2_2's Avatar
ya a test pipe is gonna make ur exhaust louder, if u have an aftermarket catback. It shouldnt affect gas mileage however your probably gonna smell bad, but its the life u live for performance
Old Apr 13, 2007 | 10:43 AM
and you think a test pipe is going to do it for you?</TD></TR></TABLE>
top end when i pull on s2k's.
Old Apr 13, 2007 | 11:28 AM
super jdm yo's Avatar
Default Re: test pipe? (1.8L_allmotormilitia)
there was an article in honda tuning about this, they installed a test pipe and two different types of hi flow cats, and the test pipe got ONE extra horse power over the hi flows. not a lot sense to pay ticket cost for one horsepower.
any type of alteration to your car's breathing and farting system is going to effect your gas mileage, for better or worse
