What would cause code 16 all of the sudden?
Old Oct 6, 2007 | 07:39 PM
s10cky's Avatar
Default What would cause code 16 all of the sudden?
I was driving my car, and slowly it started too run like crap. Its throwing a code 14 and 16, the IACV code and Injector code. I have replaced the IACV with 3 used units with no luck, which leaves me with the price of a new one.
But the injectors? can they go bad.
Old Oct 6, 2007 | 08:14 PM
silverEG6's Avatar
get your ecu checked out make sure its not goin bad
Old Oct 7, 2007 | 05:53 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
maybe one of your injectors is clogged with something. also, have you checked the iacv wiring?
Old Oct 7, 2007 | 06:02 AM
s10cky's Avatar
I'll check out the ecu. I never checked the Iacv wiring, I figured rywire.com new what they were doing, lol. So I guess i'll check that out.
Old Oct 7, 2007 | 03:39 PM
lol, that rywire conversion harness is connected into more, older wiring that they have no control over. use a multimeter to check for continuity in your iacv wiring going to the ecu.
Old Oct 7, 2007 | 03:52 PM
Chiovnidca's Avatar
Default Re: (full Circling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by full Circling &raquo;</TD></TR><TR><TD CLASS="quote">maybe one of your injectors is clogged with something. also, have you checked the iacv wiring?</TD></TR></TABLE>
A clogged injector wont cause a code 16. It's an electrical fault. You can check the wiring to them, the resistance of the injectors, the resisters if it has em. If all that tests good you could have a bad main relay.
Old Oct 8, 2007 | 11:01 AM
s10cky's Avatar
What if there is a leak from the fuel rail near the injector?
Also, where do I get the specs. on the ohms for stock obd1 b-series injectors?
Old Oct 8, 2007 | 12:55 PM
s10cky's Avatar
BUmp.
Old Oct 8, 2007 | 02:06 PM
Chiovnidca's Avatar
Default Re: (s10cky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">
Also, where do I get the specs. on the ohms for stock obd1 b-series injectors?</TD></TR></TABLE>
10-13 ohms if I remember right.
Old Oct 8, 2007 | 04:39 PM
s10cky's Avatar
Default Re: (Chiovnidca)
I found a wire on my obd0 to 1 harness that was slit for some reason. I found a pinout guide turned out too be injector # 4.
One more question. When the car idles up and down from 1 to 1400 rpms that is the iacv or the fitv.
Old Oct 8, 2007 | 04:45 PM
Duane_in_Japan's Avatar
Surging idle can be a dozen things, do a search for "fuel cut strategy" dont pick a forum, just look at them all. Dont pick a subject, pick words in the post.
95% of my code 16 fixes was a bad engine main relay, it controls power to the injectors, the other fix was a computer.
Most of the time a bad relay is a no start due to no fuel pump, less often the other half of the relay goes bad and gives a code 16.
GolfIVTyBiggums
Nov 19, 2006 10:37 AM
tdo
18
Oct 15, 2005 02:02 PM
ludelvr
Mar 13, 2005 05:57 PM
type Gendy
Aug 2, 2003 05:44 PM
EF_LSVtec
Dec 22, 2002 07:16 PM
