B18C block, Chrome-Nikel cilinder wall tickeness.
Old Jun 19, 2002 | 12:36 PM
pinota's Avatar
Default B18C block, Chrome-Nikel cilinder wall tickeness.
Hi,
Need to know what´s the Chrome-Nikel wall tickeness on the B18C block.
In the bottom of the block i can see the Chrome-Nikel sleeve of 3.5mm.
Is the Chrome-Nikel sleeve of 3.5mm from the top to low base of the block ?
I need to use 81.5mm or 82.mm pistons, sleeving the block to one of this measures will disapper the chrome-nikel sleeve ?
Will it be safe ?
My machinery shop is asking me these questions to start working on the block.
Thanks,
Pinota
Old Jun 19, 2002 | 12:45 PM
sgT's Avatar
sgT
Default Re: B18C block, Chrome-Nikel cilinder wall tickeness. (pinota)
you can go to 82mm safely for NA application
Old Jun 19, 2002 | 01:39 PM
FAST94GSR's Avatar
New User
thought you recommended against going to 82mm to some dude in a post a few days ago or a week ago or something
Old Jun 19, 2002 | 04:03 PM
pinota's Avatar
Default Re: B18C block, Chrome-Nikel cilinder wall tickeness. (FAST94GSR)
Thanks, sgT.
I hope i´ll have my ITR running in 3 weeks.
Pinota
Old Jun 19, 2002 | 07:40 PM
t's Avatar
t
I wouldnt want to bore it to fit 82mm pistons, but thats just me.
Old Jun 20, 2002 | 07:51 AM
pinota's Avatar
Default Re: B18C block, Chrome-Nikel cilinder wall tickeness. (t)
What head gasket to use ?
82.mm bore head gasket ?
Thanks,
Pinota
Old Jun 20, 2002 | 08:25 AM
sgT's Avatar
sgT
Stock gasket
Old Jun 20, 2002 | 08:41 AM
pinota's Avatar
Default Re: B18C block, Chrome-Nikel cilinder wall tickeness. (sgT)
Thanks.
Pinota
Old Jun 20, 2002 | 10:04 AM
Big Phat R's Avatar
I was wondering if any one new if you can get sleeves with Nikasil linings....say if you bore out a B18C5 to 84+ mm..
Anyone know?
Old Jun 20, 2002 | 10:39 AM
sgT's Avatar
sgT
Default Re: B18C block, Chrome-Nikel cilinder wall tickeness. (Phat Bastard)
why?
Old Jun 20, 2002 | 10:41 AM
Big Phat R's Avatar
Just wondering
PB - who seeks knowledge at all times
Old Jun 20, 2002 | 10:48 AM
sgT's Avatar
sgT
probably not.
Old Jun 20, 2002 | 12:56 PM
pinota's Avatar
But, if i bore the B18C stock 81.mm to 82.mm i´ll lose the Nikasil layer ?
I just can bore the block to 82.mm or i have to put some Nikasil treatment or new sleeves ?
I´m very confused right now.
Old Jun 20, 2002 | 12:59 PM
sgT's Avatar
sgT
there is no nikasil layer
just bore it and be done
Old Jun 20, 2002 | 01:06 PM
Big Phat R's Avatar
They reinforce the walls with something though (I thought it was Nikasil)....but then I found this...
Aluminium pistons and cylinder liners
Whether an engine is responsive and high-revving depends very much on the inertia of reciprocating parts, i.e., crankshaft, pistons and connecting rods. While crankshaft material is still bounded to steel for reasons of sheer strength, pistons of high-performance engines are usually made of aluminium. The lighter the pistons, the higher the revs and power the engine can obtain.
Using alloy pistons is not very costly, what prevents most mass production all-alloy engines from using them is the friction generated between pistons and cylinder walls. Strangly the contact between two aluminium surfaces results in high friction - much higher than between cast-iron and aluminium. Therefore many engines with aluminium block have to employ cast iron pistons.
The most common solution is to insert a thin cast-iron liner to the cylinder, covering the cylinder wall and surrounding the aluminium piston. Of course, this lifts production cost a bit.
An alternative solution was introduced by Chevrolet Vega in the mid-70s. Its Cosworth-designed all-alloy engine employed iron-coated aluminium pistons, thus the block could be linerless. However, it's still more expensive than a cast-iron liner while not delivering as good performance as Nikasil treatment.
Instead of a cast iron liner, Nikasil treatment coats a layer of Nickel-silicon carbide to the inner surface of aluminium cylinders. Since the Nikasil layer generates even less friction than cast iron liner, revability and power are both enhanced. Moreover, it is only a few hundreds of a millimetre thick, therefore the spacing between adjacent bores can be reduced considerably, making the engine smaller and lighter.
Since the early 70s, Nikasil treatment has been one of the most favoured solutions used by high-performance cars. It also proved very popular in the high performance motorcycle world especially in two strokes. Less Friction also means less wear, Porsches Nikasiled cylinders are said to out last the car.
The last alternative is a fiber-reinforced metal (FRM) cylinder sleeve, which is used by the Honda NSX 3.2-litre. Its cost and power / space efficiency are both half way between cast-iron liner and Nikasil. A fiber-based material in the form of cylinder sleeve is first inserted into the die of the block. Melted liquid aluminium is poured into the die and integrates with the fiber sleeve. Then the cylinder wall is machined to the desire bore dimension, leaving only 0.5 mm thickness to the fiber sleeve which covers the cylinder wall. It generates lower friction than an iron liner, thus improves revs and power. Moreover, the fiber sleeve reinforces the block, allowing the distance between adjacent bores to be reduced yet maintain mechanical strength.
Old Jun 20, 2002 | 01:09 PM
sgT's Avatar
sgT
B18C has a ribbed cast iron cylinder sleeve which is cast into the block.
What you are reading on possibly applies to the h22a
Old Jun 20, 2002 | 01:28 PM
Big Phat R's Avatar
Honda's motorcyle engines use Nikasil - I wonder why not on their car motors?
Old Jun 20, 2002 | 01:32 PM
sgT's Avatar
sgT
like i said, h22a probably uses it.
but b-series all std iron liners with the b20b/z using the FRM
Boostedvti
Oct 21, 2010 02:32 PM
dy5c00
Sep 8, 2004 07:04 PM
Ri5e
Sep 7, 2002 08:20 AM
dlric
Jun 24, 2002 10:54 AM
d mafia
Mar 27, 2002 11:30 AM
