Lights love to dim. WTF
Old Oct 5, 2007 | 07:29 PM
HondamanXxX's Avatar
GO GIANTS!
Default Lights love to dim. WTF
Modified by HondamanXxX at 7:42 AM 10/18/2007
Old Oct 5, 2007 | 08:38 PM
Murk 'EM's Avatar
Default Re: Lights love to dim. WTF (HondamanXxX)
it just happens... both my cars do that... i have a brand new battery in my hatch with a new motor it does it... and i got a new motor in my accord ... older battery but still it does it... its just the change in voltage and the alternator cant match it that instant so it draws a little and dims everything .. its nothing to worry about
Old Oct 5, 2007 | 08:41 PM
DohctorVtec's Avatar
Default Re: Lights love to dim. WTF (Murk 'EM)
My car does it as well. I have a 8 month old battery. Don't worry about it nothing that's going to affect your car.
Old Oct 5, 2007 | 10:05 PM
rwfsgv's Avatar
voltage regulator
Old Oct 5, 2007 | 10:11 PM
ekb16's Avatar
mine does that also
Old Oct 5, 2007 | 10:15 PM
994door's Avatar
Default Re: (ekb16)
mine did that after the swap... i just cut the wire coming fromt the ecu that controls the voltage regulator. works fine now, puts the same amount of vol as it should.
Old Oct 6, 2007 | 08:02 AM
EK_B's Avatar
Check your grounds, maybe a grounding kit would help.
Old Oct 6, 2007 | 10:16 AM
Murk 'EM's Avatar
Default Re: (EK_B)
no.. a grouding kit wont help..... i have a voltage regulator and a grounding kit on my accord and it still does it (a little) dont waste your money just live with it
Old Oct 6, 2007 | 10:22 AM
GO GIANTS!
Default Re: (Murk 'EM)
Just gets me mad when my lights go from bright to dim. Like wtf i can bearly see with them.
Anybody know what wire it is or anymore info on it?
Old Oct 6, 2007 | 10:27 AM
GO GIANTS!
Default Re: Lights love to dim. WTF (solbrothers)
To where you can bearly see the road?
Old Oct 6, 2007 | 10:35 AM
Murk 'EM's Avatar
so turn your brights on if your bitchin about it that much if their THAT dim then the brights will seem like driving lights chill out thats just what cars do
Old Oct 6, 2007 | 10:36 AM
gsxr1k05's Avatar
hid upgrade
Old Oct 6, 2007 | 11:14 AM
Brick Top's Avatar
Default Re: Lights love to dim. WTF (gsxr1k05)
the thick white wire that bolts down to the alternator terminal, there is another nut under the first one. check to see if its loose. basically the connection is sandwiched between two nuts. it cured my problem. not saying you'll have the same.
Old Oct 6, 2007 | 08:22 PM
4doorekITR's Avatar
my car does that too,even with new battery and alternator.It seems like it runs shitty when it dims also..I have a voltage gauge and its constantly jumping from 12-14.Ive upgraged all the gronds on the entire car as well.Im totally stumped
HornsManiac
Jul 6, 2016 06:53 AM
bcintron95
Oct 11, 2013 06:59 PM
lizp
Jan 3, 2011 04:36 PM
bajazteg
Jan 30, 2003 04:09 PM
