Did ALL '96 Civic EX's come with door lock remotes?
Old Oct 5, 2007 | 04:04 PM
Mangotreemechanic's Avatar
Default Did ALL '96 Civic EX's come with door lock remotes?
My owner's manual has a page about remote key fobs. Previous owner never gave me one (or two). Am I supposed to have one? Does my car have the remote capability? If so, would a dealer be able to provide a remote key fob?
Thanks.
Old Oct 5, 2007 | 04:26 PM
crazyguy's Avatar
Default Re: Did ALL '96 Civic EX's come with door lock remotes? (Mangotreemechanic)
i think it was optinoal at the time..your dealership can provide u one or two but they will charge u for those
Old Oct 5, 2007 | 06:37 PM
geebs's Avatar
Default Re: Did ALL '96 Civic EX's come with door lock remotes? (crazyguy)
most ex and lx's 96-98 all had them.. they're integrated into the factory radio..
you can check by removing it and seeing if it has an antenna on the back of it
Old Oct 5, 2007 | 07:18 PM
gator1's Avatar
Default Re: Did ALL '96 Civic EX's come with door lock remotes? (geebs)
yeh mine did but stop working when i got a new cd player so if you have a cd player it wouldn't work anyway
Old Oct 5, 2007 | 07:26 PM
actek23's Avatar
Default Re: Did ALL '96 Civic EX's come with door lock remotes? (gator1)
http://www.handaaccessories.com/civic98.html
Keyless Entry for HX and LX
Genuine Honda Civic keyless entry kit. Adds remote locking and unlocking of doors along with panic feature that sounds horn and flashes lights when pressed. Includes 2 remotes,
Factory Radio must still be installed for keyless entry to work.
All of the HX and the LX models have the receiver built into the factory radio. There is nothing to install into vehicle. Simply program the remotes to your Civic by turning the ignition on and off and pressing the lock/unlock buttons.
Honda's Retail $92.00
our Price $66.00
Old Oct 5, 2007 | 08:02 PM
99fbpem1's Avatar
Default Re: Did ALL '96 Civic EX's come with door lock remotes? (actek23)
pretty cheap for autotmatic doorlocks. Not that the oem alarm would protect your car, but a cheap alternative to buying an aftermarket alarm. But once again... do not think it will protect your car
Old Oct 6, 2007 | 03:16 PM
Thanks, to all of you.
Good info. The Honda radio is still installed. But it is beginning to fail. Lousy volume control, etc. I'll check the radio. Local dealer said it was an option back then '96, and they will check if mine is working/intalled if I drop by.
Old Oct 6, 2007 | 03:46 PM
99fbpem1's Avatar
could you put an integra cd player in and still have the OEM security option? Just curious
Old Oct 6, 2007 | 07:42 PM
hbteg6's Avatar
my 96 civic ex came power door locks
Old Oct 7, 2007 | 09:57 AM
importdreamer's Avatar
Default Re: (hbteg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by actek23 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.handaaccessories.com/civic98.html
That's not true. Schose (spelling) makes a wire harness that allows you to retain keyless entry (and your dome light) and have an aftermarket headunit. It looks like a normal aftermarket install clip but it has one extra clip on it that runs to the stock head unit. I put mine in the glove box. Or you can just leave it in place and install the new headunit down by the cup holder. It looks cleaner in my opinion.
Old Oct 7, 2007 | 01:11 PM
Redbone's Avatar
Wow! Good thing I have a 99 cause i got a new stereo a LONG time ago and the keyless still worked fine.
Old Oct 18, 2007 | 12:50 AM
I went to the dealer and found out that my car, even with the factory radio, does not support remote keyless entry.
danillobh84
Nov 27, 2011 04:38 PM
jshooter
33
Sep 23, 2009 07:05 PM
vviiasa
Aug 5, 2008 10:10 PM
jake15348
Jun 24, 2005 09:12 AM
imadigitalgod
Oct 31, 2004 09:11 AM
