94 civic horn...?
Old Oct 5, 2007 | 10:53 AM
ge_ej1's Avatar
Default 94 civic horn...?
my horn doesn't work...i looked at the fuses and they were fine, got a new horn and still no luck? anyone know what the problem could be?
Old Oct 5, 2007 | 11:14 AM
skcivic4life's Avatar
Default Re: 94 civic horn...? (ge_ej1)
just buy train horns :-)
mabey a problem with the actual button you push?
Old Oct 5, 2007 | 11:43 AM
ge_ej1's Avatar
Default Re: 94 civic horn...? (skcivic4life)
maybe...? i did have to switch my steering wheel? maybe i forogt to plug something back in? i will try that
Old Oct 5, 2007 | 12:01 PM
B18C5-EH2's Avatar
Former Moderator
Loved
What kind of steering wheel? Stock with an airbag? Aftermarket?
Stock 1994 Civic wheel will have an airbag and a "cable reel/clock spring" that is a ribbon that's wound and powers up the airbag and horn. You have to ditch the cable reel when adding an aftermarket wheel, so you must wire it up custom to make it work with the horn button.
Edit:
Even if you've got a stock one the cable reel might not be plugged in, or it was damaged when you swapped wheels. They are VERY easily damaged because they can only be wound so tight in either direction before they snap.
Is your SRS light on too?
Old Oct 5, 2007 | 01:04 PM
B18C5-EH2's Avatar
Former Moderator
Loved
BTW FYI here's a cable reel - it's number one in the diagram:
New ones are like $260.00 or more, but if you get a used one it needs to be taped up so nobody can spin it so that it isn't off center, and if installing a new one you must make sure your wheel is dead centered prior to the install.
Old Oct 28, 2007 | 10:26 AM
ge_ej1's Avatar
Default Re: 94 civic horn...? (B18C5-EH2)
yeah, my SRS light is on...and my horn does not work....i still have the stock steering wheel on it? can i go the junk yard and get one from there? or can i just wind up my old one and use it again? i really need my horn to start working again...so many wierd drivers out there....aha....
thanks again
Old Oct 28, 2007 | 12:21 PM
sprinthart's Avatar
id bring that thing to da dealership and get tht srs lite fixed
Old Oct 28, 2007 | 12:25 PM
philosofy1's Avatar
Default Re: 94 civic horn...? (sprinthart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprinthart &raquo;</TD></TR><TR><TD CLASS="quote">id bring that thing to da dealership and get tht srs lite fixed</TD></TR></TABLE>
the only way to fix the "light" is for him to replace the reel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_ej1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, my SRS light is on...and my horn does not work....i still have the stock steering wheel on it? can i go the junk yard and get one from there? or can i just wind up my old one and use it again? i really need my horn to start working again...so many wierd drivers out there....aha....
thanks again</TD></TR></TABLE>
your airbag reel is broken. unfortunately you cannot reel it back up. you can take the chance of pulling one off at the junkyard, but the chances of that not breaking in the process or already broken is pretty high.
you can either buy a new one at the dealer or go quick release hub and wheel.
the srs reels are sensitive and do not take much to break.
Old Oct 29, 2007 | 04:08 PM
ge_ej1's Avatar
Default Re: 94 civic horn...? (philosofy1)
thanks guys....i went to the junk yard and got one from there.....i was lucky to find one in decent shape.....bolted it right up and my horn worked....yay!!!!
anywais i got it for free, took my old one with me inside and said i wanted to get something like that, swapped it out in the junk yard, came back and said that i could not find one, but really i did....haha....i guess i just swapped it and that's all, nothing wrong with that right?
anyways i reset my SRS light and it is gone now when i start up my motor. if that is so, does that mean that my air bags will work if i do get in a accident? just wondering, or is just that the light is off and the air bag will not work?
Old Oct 29, 2007 | 05:05 PM
Harryflores's Avatar
pin # 6 is your HORN!!!
here's more info
https://honda-tech.com/zerothread?id=1485735
Old Nov 8, 2007 | 07:25 AM
ge_ej1's Avatar
Default Re: 94 civic horn...? (Harryflores)
thanks again guys....it was any easy fix, but hard to find at the junk yard
BlitzSix
13
Apr 6, 2009 01:49 PM
Degameth
Honda Civic (2001 - 2005)
Feb 28, 2007 08:00 PM
es_squared
Sep 21, 2006 09:11 PM
BlazingSIRT
May 8, 2003 05:17 AM
CWITR
Dec 10, 2001 10:43 PM
