can't install valve seals...wtf
Old Oct 4, 2007 | 11:35 AM
99blackdc2's Avatar
Default can't install valve seals...wtf
i searched and found the post on how to do it..now the problem is the seals dont "pop" on. in the post it says just push them into place. no good...wont go on. Im pushing pretty damn hard. the OP says it is unnecessary to hit the seal driver with a hammer...i mean im not going to clobber the thing but should i tap the seal driver lightly? i dont wanna expletive the new seal up and hafto go to honda for more...
thanks
the post im referring to is:
https://honda-tech.com/zerothread?id=1604753
Old Oct 4, 2007 | 12:21 PM
( o )( o )'s Avatar
Default Re: can't install valve seals...wtf (99blackdc2)
i think a deep 10mm or 12mm socket on top, with a little tap-tappy might do the trick....
Old Oct 4, 2007 | 03:49 PM
soaringchimp's Avatar
Be careful when tapping those seals into place. You can actually drive the rubber centers right out of the steel skirts if you tap too hard.
Old Oct 4, 2007 | 07:06 PM
99blackdc2's Avatar
yep...i definetly did that and i'll be heading to honda soon...i didnt even tap it that hard...i was using a 12mm deep...recomend a better size? better yet...where can i get the correct driver..is it cheap? dont feel like buying seals every time i hee-man a socket thru them...lol
Old Oct 6, 2007 | 09:45 AM
hybrid_KJ's Avatar
Default Re: (99blackdc2)
use a 10mm twelve point to push them on. Don't tap. Alot of times there is a little rubber left over from the previous seal that needs to be removed with a pick so that the new seal seats well. I've replaced those probably 20 times or so and have never had to tap them on.
Jdmkids Manny
Engine Machining & Assembly
Mar 13, 2016 01:13 PM
forsakenriceboy86
Dec 3, 2009 04:36 PM
Agito
May 22, 2008 07:57 AM
Ryan C
Nov 29, 2003 09:23 AM
acme
Apr 19, 2002 02:25 PM
