Vtech solenoid??
Old Oct 4, 2007 | 07:34 AM
onepoint-gsr's Avatar
Default Vtech solenoid??
When I give my car WOT at about 6500-7000 RPM's, its revving real high but not going anywhere. It pulls hard up til then but once it gets there (6500-7000) RPM range it struggles. It will hit the rev limiter early at about 7700 RPMs and it will throw CEL. CEL will stay on, and once I turn the car off then back on it will go away. The reason I say vtec solenoid is I've heard that vtec solenoids are 2 stages and it seems the second stage isnt engaging. correct me if Im wrong. I dont have a scanner, and its a 1995 Acura Integra GSR with original motor. Ive already checked the oil level and its good. LMK what you think.
Old Oct 4, 2007 | 08:42 AM
underb00steg6's Avatar
Default Re: Vtech solenoid?? (onepoint-gsr)
something is wrong with your dizzy, my friend had a similar problem .....I believe it was the coil im not sure maybe the ignitor.....well its one of the two
Old Oct 4, 2007 | 08:43 AM
Dogginator's Avatar
Daisy... Daisy...
VTEC not VTECH like in the title.
Your GSR has only one stage of VTEC at ~4400 RPM. The ~5750 RPM sound change is from the IAB opening.
Pull the code for the CEL. There is an instruction link in the Integra FAQ thread.
Old Oct 4, 2007 | 09:56 AM
Default Re: Vtech solenoid?? (Dogginator)
I will see what code it gives me. It has a MSD dizzy on it. I will check out the code and see what integra faq.'s say.
Thanks for the help.
Old Oct 4, 2007 | 11:10 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
its most likely not ur dizzy... its either low oil pressure or a dirty vtec solenoid harness... check ur CEL and let us no wat code it is
jawsiiv
Sep 12, 2009 08:24 PM
stealthpenguin
Jun 6, 2007 11:40 PM
honda4674
Mar 16, 2006 05:58 PM
t_lager
Jul 17, 2005 10:38 AM
shipsaeki
Jun 10, 2003 06:21 PM
