CEL, P1259: VTEC failure, extensive troubleshooting. HELP!
Old 06-06-2007, 06:40 PM
stealthpenguin's Avatar
Default CEL, P1259: VTEC failure, extensive troubleshooting. HELP!
The car is a 98 GS-R, 93,000 mi. with I/H/E. Stock everything else.
Computer shows code P1259, VTEC System Malfunction.
Code comes back after every ECM reset after taking car into VTEC range (past 5400 RPM's).
The car stays in limp mode (runs rich, poor MPG). But only when the car is pushed (above 6000 RPM's) does the 5,000 RPM rev limiter kick in. So, usually when I drive the car around the CEL stays on and I can drive the car past 5400 RPM's with no VTEC engagement and no rev limiter.
Every step of the Helm's manual troubleshooting has been followed except ECM replacement.
The following things have been checked as OK:
- Wiring
- Oil level
- Oil pressure
The VTEC solenoid/spool-valve assembly has also been replaced with a new unit.
The 90,000 mile maintenance was also done.
I am working on finding an ECM to swap in and check if that's the source of the problem.
Solutions/testimonials?
This problem is driving me INSANE.
Old 06-06-2007, 11:40 PM
Default Re: CEL, P1259: VTEC failure, extensive troubleshooting. HELP! (stealthpenguin)
Anyone?
Michael Ancira
01-15-2017 04:49 PM
jawsiiv
09-12-2009 08:24 PM
DohctorVtec
01-16-2007 05:43 AM
Cuda
89
01-16-2006 10:58 AM
ninety9ex
01-26-2004 07:40 PM
Quick Reply: CEL, P1259: VTEC failure, extensive troubleshooting. HELP!
