cometic head gaskets?
Old Oct 2, 2007 | 11:21 AM
White91EF's Avatar
Default cometic head gaskets?
ok so i'm rebuilding a d16a6, i was looking into the cometic mls head gaskets. I'm keeping the stock bore of 75 mm.. however the smallest bore listed on the cometic site is 75.5 mm... do they make a head gasket for a stock size bore? or do i use the 75.5 mm one?
Modified by White91EF at 12:33 PM 10/2/2007
Old Oct 2, 2007 | 11:33 AM
Autoworks's Avatar
Default Re: cometic head gaskets? (White91EF)
Get a OEM Honda gasket
Old Oct 2, 2007 | 11:36 AM
White91EF's Avatar
Default Re: cometic head gaskets? (Autoworks)
yea i was thinking of using a honda one, a friend of mine told me they updated all the gaskets to MLS type gaskets, is that true?
Old Oct 2, 2007 | 02:10 PM
Tippyman's Avatar
Getting a D16Y8 gasket will be your best bet. I run a Cometic and regret getting it. It's exactly the same as a 92+ OEM honda one.
Old Oct 2, 2007 | 02:34 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White91EF &raquo;</TD></TR><TR><TD CLASS="quote">ok so i'm rebuilding a d16a6, i was looking into the cometic mls head gaskets. I'm keeping the stock bore of 75 mm.. however the smallest bore listed on the cometic site is 75.5 mm... do they make a head gasket for a stock size bore? or do i use the 75.5 mm one?
Modified by White91EF at 12:33 PM 10/2/2007</TD></TR></TABLE>
if you rebuild the motor, wouldnt you want to freshen up the bores? make it a 75.5
Old Oct 2, 2007 | 03:01 PM
89efDUSTY's Avatar
Default Re: cometic head gaskets? (Tippyman)
y8 gasket &gt; z6 gasket &gt; a6 &gt; cosmetic...IMHO
Bump the compression with the y8 gasket LOL
Old Oct 2, 2007 | 03:03 PM
Default Re: cometic head gaskets? (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> cosmetic</TD></TR></TABLE>
it's just for looks?
Old Oct 2, 2007 | 03:09 PM
89efDUSTY's Avatar
Default Re: cometic head gaskets? (STREETWERKZ)
it's just for looks? </TD></TR></TABLE> Gay expensive looks...
Old Oct 2, 2007 | 03:16 PM
SIred91's Avatar
Rainman
lolol
Old Oct 6, 2007 | 03:30 PM
AllMotr's Avatar
go oem, i have a cometic with 11,000 kms and its already done, 14psi daily and track is 21psi and it just doesnt handle it and i waited 3 months for this headgasket.(.074)
JDM3JDude
Nov 14, 2012 02:53 AM
Honda_Tech01
Jun 23, 2008 08:42 AM
t57b18
Jan 29, 2006 05:38 PM
Lmgrcivic
Feb 6, 2005 04:55 PM
mrx
Oct 2, 2004 09:08 PM
