ECU CODES 2,22,23 How do i fix/override? B16a obd0
When i take my hatch into the V-Tec it kicks off and the check engine light comes on. i checked the codes seemd to be knock sensor, oxygen sensor #2, and Vtec Pressure Valve.I checked the wiring it seems to be wired but i dont see a wire going to the knock sensor and i have no clue where to find the Vtec Pressure Valve(kinda a scrub) N e HELP??? THNX
This should be very helpful https://honda-tech.com/zerothread?id=1558301
The VTEC solenoid is on the passenger's side of the head on the exuast side, it's a small cylinder that has a green electrical connector on it. Either the wiring is done poorly or it needs to be cleaned.
Since you have two other common wiring-related codes, I'd suggest that you go over your wiring harness thoroughly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">This should be very helpful https://honda-tech.com/zerothread?id=1558301
BUZZ!!!
Try again. Where's codes 22 and 23?
</TD></TR></TABLE>BUZZ!!!
Hmmm thanks for the help i think its my wiring to the ecu, i didnt do it my self but i did take a look at it and everything seems wired but ims go check again. i might have ti re-wire myself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civicSiRacer »</TD></TR><TR><TD CLASS="quote">Hmmm thanks for the help i think its my wiring to the ecu, i didnt do it my self but i did take a look at it and everything seems wired but ims go check again. i might have ti re-wire myself</TD></TR></TABLE>
Yeah, just because it's got wires going to it doesn't mean it's wired properly. Do you have the Factory Service Manual with VTEC Supplement? If not, you can download both of them through a link in the FAQ. There are troubleshooting procedures in there.
Try this to start: https://honda-tech.com/zerothread?id=1812135
B Dap
Oct 14, 2009 02:05 PM
Freeltec
Jul 23, 2003 05:38 PM
juicy.koreans.suck
Dec 26, 2001 09:34 AM
