Yet another P28 question...
Old Oct 1, 2007 | 12:13 PM
89D15CRXDX's Avatar
Default Yet another P28 question...
OK, I think my ECU is fried. I bought it off of Ebay a while back. When I turn my key the check engine light doesn't come on, even for a second. Isn't that how you can determine if you ECU is bad? I heard that somewhere before that the check engine light is supposed to come on for a second or two when you turn the key. I unplugged my MAP sensor and my check engine light didn't come on. But it did mess up the idle for a second or two. If this is the case, it might explain why my VTEC has never engaged. I haven't ever really endulged in the whole ECU technical aspect before. The car DOES start and run fine. Except for the surging idle thing.
Modified by 89D15CRXDX at 4:44 PM 10/1/2007
Old Oct 1, 2007 | 03:00 PM
89D15CRXDX's Avatar
Default Re: Yet another P28 question... (89D15CRXDX)
Anyone want to help out? Anyone? Simple question requiring a simple answer.
Old Oct 1, 2007 | 03:27 PM
USDMCIVICHATCH's Avatar
do you have a bulb in your cluster? if the car runs then I don't know....
Old Oct 7, 2007 | 12:55 PM
dynimitejack's Avatar
did you ever find out what the problem was? im kind of in the same situation
Old Oct 7, 2007 | 01:01 PM
hondaon18's's Avatar
Default Re: Yet another P28 question... (dynimitejack)
i bet you that your bulb for your check engine light don't work. because if you turn your car on and the check engine light don't come on then maybe your bulb is burnt. i would remove my cluster and replace the little bulb for the check engine.
butter99
15
Dec 18, 2008 04:27 PM
1999all_motoR_teg
Jun 28, 2005 07:49 PM
EVIL TYPE R
Feb 21, 2005 02:31 PM
