AFTER DONE A B18 SWAP BUT NEED HELP WITH my Exhaust system..
I SWAP A B18 engine in my civic hatch
but my question is..if i need to replace a exhause system.i should get a gsr exhaust or i should get a civic exhaust?? please help..
Re: AFTER DONE A B18 SWAP BUT NEED HELP WITH my Exhaust system.. (DJNauTicz)
Your chassis hasn't changed since you put in your swap, so you want a civic hatchback exhaust definately.
did u mean header?? your chassis does not change..u will still need civic cat back...but there are some welding required.
Re: AFTER DONE A B18 SWAP BUT NEED HELP WITH my Exhaust system.. (vlc92189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 »</TD></TR><TR><TD CLASS="quote">not always</TD></TR></TABLE>
from where header downpipe meets the cat..cause the flanges are off
Re: AFTER DONE A B18 SWAP BUT NEED HELP WITH my Exhaust system.. (crazyguy)
yeah i always want it to know this. So from headers to downpipe u need a gsr and then the cat back cat fit the downpipe from the civic.
Re: AFTER DONE A B18 SWAP BUT NEED HELP WITH my Exhaust system.. (solbrothers)
so if you buy the cat back exhaust for the civic that has a stock engine and you get a b18 there will be no problems or you have to weld it?
Re: AFTER DONE A B18 SWAP BUT NEED HELP WITH my Exhaust system.. (Djole_V)
when your swapping in a B series you dont need to change anything, but you need the B series Cat so everything will hook up
Re: AFTER DONE A B18 SWAP BUT NEED HELP WITH my Exhaust system.. (sleeperrex)
no i ment when i or if i get a cat back exhust before the engine swap will it work with the engine and everything line up good.
i changed with a b18 Header also...so i was wonder should i get a civic exhaust or a integra...some tell me might need weldin and some dont..so i really dont know....or i should get a civic exhaust system and a GSR cat that will bolt rite on with no problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperrex »</TD></TR><TR><TD CLASS="quote">when your swapping in a B series you dont need to change anything, but you need the B series Cat so everything will hook up</TD></TR></TABLE>
thats right..thats another way to do it..
slimjimdanny
01-10-2007 02:47 PM
redGSRguy
12-20-2006 03:49 PM
