about an engine swap.
Old Oct 1, 2007 | 11:26 AM
civycoop's Avatar
Default about an engine swap.
well i blew my y8 yesterday
and i'm looking at getting a d15b
i have a 97 ex.
Engine
Transmission 5-Speed LSD
Distributor
Alternator
Starter
A/C Compressor
Power Steering Pump
Intake Manifold
Exhaust Manifold
Throttle Body
Clutch
Fly Wheel
Pressure Plate
thats what comes with the engine.
would i be able to use my motor mounts from my y8?
and would it wire up to my ecu or would i have to get a different ecu since
a d15b is obd1 and my ecu is obd2?
sorry i'm not that intelligent when it comes to this.
can yall help me out a little?
Old Oct 1, 2007 | 11:30 AM
Jakester9500's Avatar
you can get it to work, but you might as well get ready for the obd1 ecu or you will throw a code nonstop.
I put an obd2 oil pump in my z6 so that would work, you might want to look into doing that.
Old Oct 1, 2007 | 11:33 AM
fmrprojects's Avatar
Default Re: (Jakester9500)
u can use everything from your stock motor and you need to get an oil pump with the crank sensor on it so you wont throw a code for that. and just use all of your stock mounts
Old Oct 1, 2007 | 11:35 AM
civycoop's Avatar
so i can use my ecu
and all i would need is a oil pump for a d15b
Old Oct 1, 2007 | 11:43 AM
Default Re: (civycoop)
i think you can swap you oil pump over with the crasnk senosr and it will work. but make sure you oil pump is still good
Old Oct 1, 2007 | 11:45 AM
civycoop's Avatar
alright.
if i do need a new one
how much will it run me?
Old Oct 1, 2007 | 11:46 AM
i think like 120 bux
Old Oct 1, 2007 | 11:49 AM
civycoop's Avatar
alright thanks man.
Javier23
Dec 6, 2011 05:32 PM
wevtech
Mar 12, 2011 12:46 AM
7808
Aug 5, 2007 09:10 PM
northkai3
15
Aug 30, 2006 09:11 PM
Ehron
Oct 15, 2003 08:14 AM
