Low idle (sometimes)
Old Sep 30, 2007 | 07:59 PM
RedSix's Avatar
Default Low idle (sometimes)
I have a 2000 ex coupe and sometimes the idle is lower than normal usually on hotter days and only when the sun is out, I also notice that when I am reverseing as soon as I take it out of reverse to go into first the RPMs will drop significantly. Has anybody else had a similar problem?
Old Oct 4, 2007 | 07:53 AM
gimmezell's Avatar
I have the same car and I've been having a low idle too. It usually only happens when the outside temp is on the warm side. I've done the following.
cleaned IACV numerous times.
replaced IACV with a know working one
cleaned TB
Final result....I'm still getting low idle. I mean really low, but it never dies.
I haven't bled my coolant system yet. You/we may have bubbles in it. I may replace the O2 just because.
The only constant thing is that it usually only happens when it's hot out.
Old Oct 4, 2007 | 07:54 AM
EJ6_Hatch's Avatar
you guys running crome?
I have the same issue
Old Oct 7, 2007 | 02:32 PM
gimmezell's Avatar
I was tuned on Crome a little over a year ago and was idling just fine. My idle problem started happening a few months back.
Old Oct 8, 2007 | 05:16 PM
kiddcarbuff's Avatar
i have a 94 with the SAME issue, all stock. stupid low idle all the time. even when its cold outside, liek around 200 rpms or so. anyway to adjsut the idle?
Old Oct 8, 2007 | 11:54 PM
pho dac biet's Avatar
Hair Club President
Default Re: Low idle (RedSix)
I used to have the same issue in my 94 ej1 solved the problem by cleaning the TB and using a fuel injection system cleaner (not just the ones you mix with gas)
Old Oct 9, 2007 | 06:37 AM
howd u clean thr TB, take ur intake off and hose it w/ brake cleaner?
Old Oct 9, 2007 | 07:28 AM
playskool's Avatar
Default Re: (kiddcarbuff)
this is starting to be a characteristic of civics. just like the quarter panel herpes. its bound to happen.
a fix for me was replacing my new(er) chassis grounds (99 GSR) to my old rusty stock grounds (92si) then resetting the ECU and letting it idle for a few minutes w/ no load. i went out and puched it to redline a few times and now it doesn't do the stoplight shutters anymore.
this is one of those effed up issues thats got a different fix for everyone. search "low idle" and start to troubleshoot. don't replace and pray cause thats just gonna cost a fortune. after replacing o2 sensor, IACV, TB, ETC. all it took was a set of crusty ole cables in my box of parts that never made it back into the car.
Old Oct 26, 2007 | 05:47 PM
spinery's Avatar
bump
Joker88
May 20, 2017 10:21 AM
Joker88
May 15, 2017 07:14 PM
Tillerdrums88
Jan 14, 2013 07:55 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
