Help! with VAFC
Old Jun 18, 2002 | 05:47 PM
Stew Pidasso's Avatar
Default Help! with VAFC
I just got done wiring my VTEC controller part of my VAFC and I got a check engine light.I wired the pink and purple to the green with yellow stripe on the 26 pin connector.Can anyone confirm this please?
Old Jun 18, 2002 | 06:07 PM
John's Avatar
New User
Default Re: Help! with VAFC (Nitz5785)
What code are you throwing?
Old Jun 18, 2002 | 06:09 PM
I'm not sure but it idles like crap and its as soon as I start the car
I forgot how to check codes
[Modified by Nitz5785, 10:09 PM 6/18/2002]
Old Jun 18, 2002 | 06:25 PM
SOHCArchangel's Avatar
sounds like its tossing a map sensor code
i had this, are you sure you did not splice any wires off the iac valve?
i had played with those wires a while back, long story...
Old Jun 18, 2002 | 06:27 PM
John's Avatar
New User
Default Re: Help! with VAFC (SOHCArchangel)
Good job Misa. Yeah, it's your MAP sensor. You'll be throwing a code 4. Check your ground first, then re-check your connections.
Old Jun 18, 2002 | 06:29 PM
I'm thinking it might need the blue wire hooked up to the VTM signal wire.Anyone know what the VTM signal is and do our cars have them (94 Accord-F22b). The Apex manual says some cars don't have it..I read that the blue wire is not hooked to anything though.
i cant remeber man, ill look for my manual tommorow, this is what was before apex-i changed it again
Old Jun 18, 2002 | 06:31 PM
Default Re: Help! with VAFC (DunReit)
Yeah but it was all hooked up before for months now except for the vtec control wires and I never had a problem.(I was told by Apex'i that the vtec controller won't work on US Accords)
Old Jun 18, 2002 | 06:32 PM
dont listen to those fob's
Old Jun 18, 2002 | 06:34 PM
https://honda-tech.com/zerothread?id=157504&page=2
this was the original thread of discussion on this and it's where I'm getting my info from
[Modified by Nitz5785, 10:35 PM 6/18/2002]
Old Jun 18, 2002 | 06:38 PM
John's Avatar
New User
haha... I've lost all faith in Apex now... dumbasses...
John, who has a V-AFC, but will likely never buy another Apex'i product.
Old Jun 20, 2002 | 10:26 AM
TWG's Avatar
TWG
I wouldn't trust APEXi instructions if that's what your using... both of them for the 6th gens are wrong, even the "corrected" one...
Try to get a helms manual and find out which wire is exactly which on the stock ECU... then match the VAFC wires to the cars... that's what I did... works like a champ... although I had the first time, i had the VTEC in and out mixed up...
and the 6th gens have VTM, so i'm not sure if u have them or not...
[Modified by TWG, 11:26 AM 6/20/2002]
Old Jun 20, 2002 | 12:09 PM
kcxtremeaccord's Avatar
Default Re: Help! with VAFC (TWG)
the 5th gen 94-95 does have a VTM signal, i can have pictures of Sabastians install sometime tommorow if you need them, also the Apexi install book that he got worked perfect matched up with the ecu layout in the helms.
[Modified by ILiveNextToSabastian, 1:10 PM 6/20/2002]
Old Jun 21, 2002 | 04:42 AM
Default Re: Help! with VAFC (ILiveNextToSabastian)
I really gotta get a Helms .I have a haynes and it sucks.
Old Jun 21, 2002 | 04:56 AM
im still looking for the manual i used, ill keep looking
topsekret
Dec 22, 2002 05:49 PM
.Beaver
28
Nov 19, 2002 04:31 PM
RaVeN
Oct 17, 2002 06:50 PM
crxtreme27
Aug 9, 2002 09:22 PM
AfEn808
Jan 27, 2002 03:01 AM
