g22 hybrid no vtec?
Old Sep 30, 2007 | 01:14 AM
superturboprelude's Avatar
Default g22 hybrid no vtec?
ok we just finished a g22 hybrid swap in my friends 5thgen lude h22 head on f22b2 bottom end. The problem is that vtec is not kicking in on the dyno we check the vtec wiring pressure swtich and vtec solenoid it was all good and up to par and no metal shavings in the solenoid screen. what can it be? thanks in advance
Old Sep 30, 2007 | 10:03 AM
JTCdudeman's Avatar
Master H Technician
Default Re: g22 hybrid no vtec? (superturboprelude)
sounds like you didnt remove the oil control orfice in the F22b2 block... It must be removed to get adequate oil pressure for VTEC...
Old Sep 30, 2007 | 04:18 PM
Default Re: g22 hybrid no vtec? (JTCdudeman)
where is that located
Old Sep 30, 2007 | 05:33 PM
is it this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Khuna" &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Sep 30, 2007 | 05:38 PM
tgreene2098's Avatar
did you check wiring? a ground could be hooked up wrong
Old Sep 30, 2007 | 05:42 PM
Default Re: g22 hybrid no vtec? (tgreene2098)
yes all the wiring is good no cel code and its a 5th gen lude already prewired for vtec
Old Sep 30, 2007 | 07:56 PM
turbociv910's Avatar
yes, you are supposed to move that plug^^^
Old Oct 1, 2007 | 09:34 AM
PirateMcFred's Avatar
What are you using to tune? If it's a nonVTEC basemap that could be a problem. And you need to remove that plug if you didn't.
Old Oct 1, 2007 | 01:03 PM
Default Re: g22 hybrid no vtec? (PirateMcFred)
yea we are using hondata h22 base map we pretty dyno tune already wtih no vtec 248 whp and 235 ftlb tq. After we remove that plug we goin to go back to the dyno and try to hit 300 whp heres the dyno sheet
Dyno Sheet:
Motor:
F22 block & H22 head.
All stock.[/quote]
Old Oct 1, 2007 | 01:04 PM
where should we set the redline for this motor?
Old Oct 1, 2007 | 07:30 PM
alterdcreations's Avatar
on the stock bottom end i would go past 7,000.
Old Oct 1, 2007 | 09:01 PM
AndrePerras's Avatar
Default Re: g22 hybrid no vtec? (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">on the stock bottom end i would go past 7,000.</TD></TR></TABLE>
i wouldnt.
Old Oct 1, 2007 | 09:37 PM
DCxMagus's Avatar
Default Re: g22 hybrid no vtec? (hamadiscool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool &raquo;</TD></TR><TR><TD CLASS="quote">HOLY COW! This is insane numbers for a non-turbo. I want the mod list ASAP!</TD></TR></TABLE>
who said it was non turbo?
it's a G22 turbo and the VTEC wasn't working
Old Oct 1, 2007 | 09:58 PM
go past 7? daamn iono bout that but yea any other suggestion?
Old Oct 1, 2007 | 10:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndrePerras &raquo;</TD></TR><TR><TD CLASS="quote">
i wouldnt.
thats what i ment. lol
Old Oct 2, 2007 | 07:05 PM
lol
crx18c1
18
Apr 12, 2007 12:25 PM
Anthony1
Mar 16, 2006 12:07 AM
crispydee
Sep 29, 2004 03:30 AM
HatchBox
40
Nov 23, 2003 05:22 PM
infamousALLMTR
May 20, 2002 04:10 PM
