cai installed and now strange idle
Old Sep 29, 2007 | 03:36 PM
Prudz_lude's Avatar
Default cai installed and now strange idle
Ok so i helped install an intake that i was running on my car (4th gen srv) Since the car got written off i parted this part out and i helped the buyer install it. It worked great on my prelude but for some reason there is a very strange idle search in first gear.
When the car drives in first and you release the clutch when moving slow, coming to a stop the idle bounces 50-100 rpm. i know its not very much but the owner is a little concerned. i plugged all the vac lines so there are no leaks and we double checked after and i checked again when he brought his car back.
Do you guys think its just something to do with the egr or something like that? dirty?
Old Sep 29, 2007 | 09:51 PM
mikemjohnson's Avatar
Default Re: cai installed and now strange idle (Prudz_lude)
solution within: https://honda-tech.com/zerothread/2111120
Old Sep 30, 2007 | 06:05 AM
Prudz_lude's Avatar
Default Re: cai installed and now strange idle (mikemjohnson)
ummm iavc?
Old Sep 30, 2007 | 06:12 AM
mattsnooz's Avatar
so while in neutral with car running idle jumps for lets say 650, to 700 rmp kinda thing?
Old Sep 30, 2007 | 06:28 AM
SnlpeR's Avatar
uncap that small vacuum hose that you removed on the stop intake pipe
Old Sep 30, 2007 | 08:12 AM
Acidcrakker's Avatar
Default Re: (SnlpeR)
This is like the 7th thread this week about strange idoling and serging with new air intakes. Mabey its the weather.
Old Sep 30, 2007 | 10:07 AM
Prudz_lude's Avatar
Default Re: (Acid and paper stacks)
no its not while sitting at idle it jumps 500-600 rpm. I know the solution for that because my car did that for a while.
I have never seen this happen before. When the clutch is engaged and you release the clutch after youve shifted to second the idle bounces upwards about 50-100 rpm. Just a little bounce, its really hard to explain and really weird.
Personally i don't think its a big deal because at idle its solid as a rock but the guy i sold the cai would like to know whats up
Old Sep 30, 2007 | 10:23 AM
Default Re: (Prudz_lude)
that is strange. I had posted a thread earlier this week about the same thing. Except my Idol would jump from 500 to 2000 in neutral. I ha capped off a vacum line before installing a new air intake. I uncapped the vaccum and filed the coolant up(IDK) and it stoped doing it.
Old Sep 30, 2007 | 11:27 AM
Prudz_lude's Avatar
ill suggest that to him. its really strange becasue its just such a small idle surge.
Old Sep 30, 2007 | 11:38 AM
mgags7's Avatar
Usually, that would be a dirty IACV.
Just so you know, the problem has nothing to do with the CAI. So I wouldn't worry about it.
Old Sep 30, 2007 | 11:42 AM
Prudz_lude's Avatar
Default Re: (mgags7)
yah thats what i told him. i recall a few months back, i think it may have actually be you, someone wrote a huge write up about all the issues on the bouncing idle and other strange idle problems and how to fix them.
DC2_8.2K
Mar 31, 2007 06:57 PM
accordlove
Sep 23, 2005 10:01 AM
One2chi
Jul 9, 2005 02:05 PM
SSS2000
May 11, 2004 04:21 PM
blackhatchy
16
May 21, 2003 06:31 PM
