H22a
Old Sep 27, 2007 | 08:09 PM
bruce-si's Avatar
Default H22a
i have 92 prelude i swap out H23 to H22A and it was a auto so i did the manual swap and i put in a VAFC 2 and exshuset. i have a quastion can i put RACE GAS in my motor just about 2 gal mix with 91 chevran, will is it ok any advice thanks .
Old Sep 27, 2007 | 08:15 PM
plikit's Avatar
Default Re: H22a (bruce-si)
you CAN put race gas but you dont need it... and please try using spell check.
Old Sep 27, 2007 | 08:26 PM
98vtec's Avatar
moderator emeritus
Default Re: H22a (plikit)
it wont do anything but make your wallet thinner.
Old Sep 27, 2007 | 09:34 PM
bruce-si's Avatar
Default Re: H22a (Evil.98vtec)
so there woulden't be any power that i could get ex. advace da timing or something thanks
Old Sep 27, 2007 | 09:45 PM
98vtec's Avatar
moderator emeritus
you can advance the timing on pump gas.
reasons to run race gas:
500+whp turbo motor
fully built NA, 13:1 compression and higher......250whp+
race gas simply slows down the burn rate of the fuel thus allowing you to run more power without sacrificing ignition timing to keep it from detonating.
Old Sep 27, 2007 | 10:07 PM
preludefien
Guest
Posts: n/a
lol dude your not going to get any gains out of it...just build it and sell me your h23
Old Sep 28, 2007 | 08:44 AM
ronmoreno16's Avatar
So how did putting race gas in there go with ur wallet?
Old Sep 28, 2007 | 08:49 AM
Revi's Avatar
Default Re: (ronmoreno16)
Its useless unless you fit under one of the condition 98vtec mentioned above.
Old Sep 28, 2007 | 08:52 AM
NirVTEC's Avatar
Default Re: (Revi)
Ive made my own RACE gas but I did it to run full timing with Nitrous.....
TOLUENE FTW!
Waste of money for your setup though.....
Spend that money on tuning tuning tuning!!!!!
Old Sep 28, 2007 | 08:54 AM
Acidcrakker's Avatar
My guess is that race gas is more exspensive than pump gas.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ronmoreno16 &raquo;</TD></TR><TR><TD CLASS="quote">So how did putting race gas in there go with ur wallet?</TD></TR></TABLE>
Old Sep 28, 2007 | 09:44 AM
NirVTEC's Avatar
Default Re: (acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">My guess is that race gas is more exspensive than pump gas.</TD></TR></TABLE>
Right now, I can get 100oct for about $5/gal
At the track, they charge anywhere from $6-8/gal for 104-110 IIRC
If anyone wants to make their own race gas let me know.....I have done it with great success.
Ive made ~270whp on Pump gas with a 100 shot of Nitrous!
Old Sep 28, 2007 | 02:35 PM
boostedh22lude1's Avatar
if all you have done is a vfac your not going to gave any performance, but possibly detonation from that high of octane with a stock and untuned motor
Old Sep 28, 2007 | 04:04 PM
jdmvtec7700's Avatar
Default Re: (boostedh22lude1)
high octane burns slower and more predictably and lessens the chance of detonation. thats why you use it in high compression engines, if you have like 15:1 compression the gas would blow up even without a spark present (assuming the engine is warm). then you would have yourself a diesel
Old Nov 9, 2007 | 09:18 PM
bruce-si's Avatar
Default Re: (jdmvtec7700)
yeah thanks 4 da info i did put racing gas and i got 15.8 at da track full advance timing and vtec and 4600
Old Nov 9, 2007 | 10:28 PM
Dicorp's Avatar
Default Re: (bruce-si)
i've also heard that race gas can be leaded and damage your emissions system. hence why its only used on track cars that are not street legal. so its pretty much useless and potentially harmful for your engine and subsequently will hurt your fuel milage cause you'll expletive up your cat converter. someone correct me if im wrong though...
Old Nov 10, 2007 | 12:41 AM
Rosko's Avatar
Default Re: (::NirVTEC::)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: &raquo;</TD></TR><TR><TD CLASS="quote">
I can get 105 octane for about $2.50/gal E85 FTW!!
Old Nov 10, 2007 | 12:44 AM
Rosko's Avatar
Default Re: (Dicorp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dicorp &raquo;</TD></TR><TR><TD CLASS="quote">i've also heard that race gas can be leaded and damage your emissions system. </TD></TR></TABLE>
Its not too friendly on the O2 sensor, however you CAN get it in an unleaded form but your prolly not gonna find it at any local pump.
http://www.vpracingfuels.com
Old Nov 10, 2007 | 04:58 AM
mgags7's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">
I can get 105 octane for about $2.50/gal E85 FTW!!</TD></TR></TABLE>
You have any mpg #s yet by chance?
...and I don't mean vtakking all over town
.RTErnie
Aug 18, 2005 12:20 PM
ITR981002
Apr 25, 2005 05:58 PM
ensracer
May 5, 2004 10:53 PM
Holden
Jan 30, 2003 10:08 AM
4gvtec
Sep 17, 2002 08:58 AM
