which ecu for sohc vtec?
Old Sep 27, 2007 | 10:18 AM
1sikhatch's Avatar
Default which ecu for sohc vtec?
ok i need some advise on this, i recently swapped a jdm d15b into my si. now i need the right ecu for this motor. should i get a obd0-obd1 jumper and use a obd1 ecu or can i use a obd0 b16 ecu?
Old Sep 27, 2007 | 10:40 AM
GreenBean's Avatar
Default Re: which ecu for sohc vtec? (1sikhatch)
I am subscribing...I would think the cheaper option would be a JDM P27 ECU right? The SOHC VTEC...I think they are OBD0, but you wouldn't go wrong with a P28 OBD1 ECU, but might cost more to change overe to OBD1.
I wanna know this also,
If you are tuning, is it better on an OBD0 or an OBD1 ECU. Any differences...
Old Sep 27, 2007 | 11:01 AM
makoto's Avatar
I would think P28 (which of course is obd1). The Jdm d15b is a "three stage" vtec (for fuel economy), so the p28 isn't the exact ecu for the motor, but I would assume it would work. Maybe not...
Old Sep 27, 2007 | 11:05 AM
beatthisspeed69's Avatar
Default Re: which ecu for sohc vtec? (makoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makoto &raquo;</TD></TR><TR><TD CLASS="quote">I would think P28 (which of course is obd1). The Jdm d15b is a "three stage" vtec (for fuel economy), so the p28 isn't the exact ecu for the motor, but I would assume it would work. Maybe not...</TD></TR></TABLE>
not all d15b's are stage 3 vtec if it has 2 vtec silanoids however you spell that then yes it is???
Old Sep 27, 2007 | 12:11 PM
ludesrv's Avatar
OBD0 ecus don't have vtec other then the PR3 and PW0 (B16A ecus).
You want a P28, OBD1. I started making swap harnesses for them. PM me if you want to buy one. They are cheaper then Rywire.
Old Sep 27, 2007 | 12:16 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">OBD0 ecus don't have vtec other then the PR3 and PW0 (B16A ecus).
You want a P28, OBD1. I started making swap harnesses for them. PM me if you want to buy one. They are cheaper then Rywire.</TD></TR></TABLE> Other then you being a canuk I'd trust you
I'm sure you do great work
Always good to see more people doing stuff for these old cars
Your info is correct you do want a p28 or you can run a p08.
Old Sep 27, 2007 | 12:40 PM
GreenBean's Avatar
Default Re: which ecu for sohc vtec? (GreenBean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean &raquo;</TD></TR><TR><TD CLASS="quote"> I wanna know this also,
Any takers...
Old Sep 27, 2007 | 12:56 PM
c0d0r's Avatar
of all the shops that ive been too getting other's cars tuned obd1 is the better platform, the p28 is a very good ecu to tune with
Old Sep 27, 2007 | 03:12 PM
Crx Jimmy's Avatar
Default Re: (c0d0r)
if you want to stay obd0 you can use a ps9 and chip it with turboedit for vtec use
Old Sep 27, 2007 | 03:36 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote"> They are cheaper then Rywire.</TD></TR></TABLE>
peace of mind is worth the little extra cost.
Any takers... </TD></TR></TABLE>
obd-1 computer's use a more powerful processor. resulting in a better, more thorough tune.
Old Sep 27, 2007 | 07:07 PM
1sikhatch's Avatar
Default Re: (STREETWERKZ)
so my best option would be to get a p28 and jumper, is that all i would need?
Old Sep 27, 2007 | 09:33 PM
Rease3's Avatar
Default Re: (1sikhatch)
i agree thats what im doing also with the dpfi obd0-1 conversino harness from j-k-tuning.com
Old Sep 28, 2007 | 08:11 PM
northemt88's Avatar
Default Re: (Rease3)
the only thing that i know is a p28 will work, maybe a p30, p72
Old Sep 29, 2007 | 06:01 PM
Rease3's Avatar
Default Re: (northemt88)
i have a chipped p28 for sale
TurbodTegra
Mar 10, 2011 12:46 PM
rockinthe94LS
Aug 26, 2008 06:25 PM
hondateg10
Mar 25, 2007 03:50 PM
cyrock
Jun 25, 2006 01:29 AM
