ecu
if your car is obd0, then you can look for the jdm pr3 or pw0. The pr3 came out of the b16a DA's in Japan. If you wanted to run an obd1 dohc vtec ecu, then you can look for the p61, p30, chipped p28
You are pretty much going to have to chip any ecu you get for your car. Even if you get a stock P30 (JDM OBD1 ecu) you will still have problems, unless you wire in a knock sensor (which almost noone does) and you will have to get the P30 chipped so that you dont always have the Check engine light on because there is no knock sensor. I would suggest either buying a US P28 or US P72 ecu and then getting it chipped for a B16. or you can buy a P05, P75 or P06 ecu and have the vtec components added to it and get it chipped with a good B16 program.
I can do the vtec conversions or the chipping for you if you need it. hit me up if you get an ecu and you want me to chip it or do the vtec conversion. I have lots of good programs for all kinds of setups from other cars I have tuned.
HAMOTORSPORTS
Performance
172
Sep 29, 2017 11:00 AM
