Help getting wide band to display AF in hondata s300 smanager
Old Sep 26, 2007 | 09:12 PM
boosted91crx's Avatar
Default Help getting wide band to display AF in hondata s300 smanager
Hi guys, i installed my AEM UEGO and used the ELD pin. i get a display in smanager in the ELD cell in the sensors window , but its in voltage, the AF cell dont do any thing, is there a way to set it to tell me my AFR in the AF cell as well?
Old Sep 26, 2007 | 10:19 PM
thomas@LPS's Avatar
Default Re: Help getting wide band to display AF in hondata s300 smanager (boosted91crx)
i know you can do it. i have my ngk wideband plugged into my eld and have it displaying voltage and af ratio. im pretty sure you need to go to options, settings then be on the wideband lambda tab then you can go in a change the parameters to match your aem's scale.
Old Sep 27, 2007 | 05:25 AM
I am looking into that and i was told the AEM needs a offset voltage as well? I am hoping to find some one here who has the AEM installed and working so i can be sure i do it correct.
Old Sep 27, 2007 | 05:41 AM
RedR's Avatar
i dont know if i got your question right but it seems u wanna change the unit type?
Go to options ---> sensors ---- AF (here select the units as air fuel ratio instead of lambda)
Old Sep 27, 2007 | 05:47 AM
hi red R , the problem i have is the AF cell in the sensors window does not work, however i see a voltage reading in the ELD cell , i have the wide band conected to the ELD pin.
Old Sep 27, 2007 | 06:01 AM
RedR's Avatar
Default Re: (boosted91crx)
so u r saying that when u r datalogging it doesnt show up anything on the tables?
Old Sep 27, 2007 | 11:10 PM
thomas@LPS's Avatar
it shouldnt matter what brand the wideband is.. they are all 0-5v sensors. for example on mine 0v=9.00-1 af and 5v=16.00-1. just use the voltage from the aem instead of mine. then you would just need to use the voltage offset to dial in the hondata to read exactly what your aem is reading. here a pic of what mine looks like.
Old Feb 2, 2008 | 09:02 PM
tunerprojects's Avatar
Default Re: (thomas@LPS)
good info, thank you thomas
xenocron
Engine Management and Tuning
Oct 12, 2012 07:46 AM
kekek-20
Jul 22, 2004 04:39 PM
B00ST2nR
Jul 7, 2004 12:15 PM
PM-Performance
Sep 10, 2003 11:56 AM
2000Accord5sp
Jul 5, 2002 06:57 PM
