funny gsr idle
Old Sep 26, 2007 | 06:28 PM
I CRX I's Avatar
Default funny gsr idle
my car idels up and down when its cold on first start up but after i start driving it, it idles perfect. is it somthing i should worry about?
Old Sep 27, 2007 | 03:26 AM
I CRX I's Avatar
any suggestions? also i seemed to have lost the small black "top" that sits on the purge valve for my crx ( the on thats connected to the map sensor) is this important? could this be the cause of the wierd idle?
Old Sep 27, 2007 | 03:27 AM
yoffer's Avatar
Banned
IACV needs to be cleaned.
Old Sep 27, 2007 | 03:37 AM
I CRX I's Avatar
would that be the E.A.I.C? <--gsr motor, and where do i clean it, what do i clean it with?
Old Sep 27, 2007 | 07:48 AM
ef_hatchback's Avatar
Default Re: (I CRX I)
cause most of the IACV's are riveted on the manifold, just de-plug it, and you'll only throw a check engine light for that....and it won't cause anything//
Old Sep 27, 2007 | 07:56 AM
accord_2dr's Avatar
Default Re: (ef_hatchback)
it could be your cooling system. does it jump from 1000-2000rpm for about 2 minutes and then stops? because mine also did this and i just bled my cooling system.
Old Sep 27, 2007 | 09:31 AM
grog's Avatar
Default Re: funny gsr idle (I CRX I)
sounds like the fast idle thermo valve, mine has gone bab 3 times. i believe it starts happening just when cold. then over time it will idle erradicly all the time
basicaly the FITV raises your idle when the coolant is cold, but the valve (which is threaded) backs itself out over time. and the valve cant shut anymore. causing the bouncing idle.
do a quick (archived) search for the fast idle or FITV, i think you will find alot on this.
theres a cover on the back of the FITV with 2 philips screws. take that off and you will see the the white plunger, which is probly set to the back of the FITV. now screw it in by depressing the plunger (which is spring loaded) and turing it with a flathead screwdriver (in the groove running through the plunger) to the right i believe, again you must depress the plunger to be able to screw it in far enough.
screw it in most or all the way.
I actualy made a plastic insert to put inside the FITV to prevent this plunger from backing out. but i havent tested it yet, i imagine that as long as it has enough holes in it and lets enough coolant through it will be fine.
i could post pics if anybodys interested.
also did you do anything to the cooling system, it could be air in the coolant.
Old Sep 27, 2007 | 09:55 AM
grog's Avatar
sorry i think may have jumped to conclusions on the FITV, you might not even have one if your motor is obd2.
also looking in my manual a quick check to see if it is the IAC, is to " with the engine running and the accelerator pedal released,disconnect the 2p connector from the IAC valve.
is there a reduction in engine rpm..........yes intermittent failure, system is ok, check poor connections or loose wires.
.................................................. .........no, substitute a known-good IAC valve and retest "
hope i didnt confuse you
Old Sep 27, 2007 | 10:28 AM
I CRX I's Avatar
Default Re: funny gsr idle (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">sorry i think may have jumped to conclusions on the FITV, you might not even have one if your motor is obd2.
hope i didnt confuse you</TD></TR></TABLE>well my car is obd1 and its idling from about 600 to 1200 and seems to have gotten worst over the last few days. it used to happen when it was just cold about 2-3 days ago but now its constant! any ideas? btw is there an FITV on a 94 gsr?
Old Sep 27, 2007 | 10:39 AM
APEX CRX's Avatar
FITV is under the throttle body. It will have small rubber coolant lies going in and out of it.
KimvdLinde
Jun 29, 2013 01:40 PM
TearSDMF89dx
Jan 3, 2012 04:31 AM
spock_rocker
Oct 17, 2007 08:11 AM
devonic
Sep 26, 2003 08:55 AM
b16vteccx
Mar 22, 2002 06:16 AM
