Whats the diffrence between a D16Z6 head, and a d16Y8 Head?
Old Sep 26, 2007 | 06:30 AM
Dasfinc's Avatar
Default Whats the diffrence between a D16Z6 head, and a d16Y8 Head?
Like the title says Whats the diffrence between a D16Z6 head, and a d16Y8 Head?
Old Sep 26, 2007 | 06:47 AM
wfocrx's Avatar
easy answer...
one is for a d16z6 and the other for a d16y8.
but really, the combustion chamber is smaller in the y8 and the y8 has more quench area to resist detonation.
also, the z6 has tumble ports (which are better suited for "top end") while the y8 head has swirl ports.
Old Sep 26, 2007 | 06:48 AM
wfocrx's Avatar
Default Re: (wfocrx)
http://www.d-series.org/forums...21761
Old Sep 26, 2007 | 06:54 AM
Dasfinc's Avatar
I kinda meant Visual diffrences, I don't know if I have Z6 or a Y8 head waiting to go on my MiniMe Swap...
Old Sep 26, 2007 | 06:57 AM
Dasfinc's Avatar
Default Re: (Dasfinc)
Also, Aside from the back corner Headbolt, can I use the Z6 Distributor, wires, plugs and Vtec solinoid?
Old Sep 26, 2007 | 07:39 AM
Dasfinc's Avatar
Bumpity, need some help on this one.
Old Sep 26, 2007 | 08:01 AM
suspendedHatch's Avatar
No. The z6/z1 distributor only works on the z6/z1. I see this question 2-3 times a week.
Old Sep 26, 2007 | 08:09 AM
Dasfinc's Avatar
Default Re: (suspendedHatch)
I had read the y8 Distributor can be altered to work on a Z6 head, can I do this the other way around? will the plugs and wires still work? If I get a Y8 Distributor, can it work with my OBD1 ECU and harness?
Old Sep 26, 2007 | 08:14 PM
wfocrx's Avatar
you can buy/make a obd2-to-obd1 dizzy adapter so don't let that stop you
bobbyx0r
Jul 30, 2011 11:47 AM
scuzz
10
Mar 8, 2010 02:03 PM
SpdKilz23
10
Apr 11, 2009 02:48 PM
98jdm_coupe
Apr 15, 2004 09:28 PM
DRKSol
Sep 5, 2003 07:05 PM
