ek with obd1 swap
u will need driver side and tranny mounts..shift linkage...p72 ecu or a chipped p28 ecu tuned by a pro..with hanress conversion to obd1...axles...complete engine harness...and all the sensors..depends on how complete the engine swap is
and about 15~17 hours of labor to do diy the swap..or $500~$700 to have a shop do it for u
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">u will need driver side and tranny mounts..shift linkage...p72 ecu..with hanress conversion to obd1...axles...complete engine harness...and all the sensors..depends on how complete the engine swap is </TD></TR></TABLE>
noob
you need all si mounts, conversion harness to run the obd-1 ecu, use your stock harness, ad convert all the stuff on the motor to obd-2 like injectors, alternator, distributor
noob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">
noob
you need all si mounts, conversion harness to run the obd-1 ecu, use your stock harness, ad convert all the stuff on the motor to obd-2 like injectors, alternator, distributor</TD></TR></TABLE>
reuse your stock tranny mount...that is fine...SI L-bracket, i suggest an aftermarket driver side mount...but you can just use an si driver side mount...
and what he says......but if the motor is an obd1...you will have to do the three wire to two wire plug...forgot the site that has the notes on this...i had to do that to mines...but i suggest just getting an obd2 swap....less mess and less hassle on the long run...plus...if you have smog...you'll be safe...i regret putting my obd1 b16 into my 98 hatch...
noob
noob
why would u need to convert those if your running obd1?
or r u saying that cause u'd be using ur obd2 wiring harness?
n would u just use the stuff off the d?
noob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">
i was addressing the same theory
yes to be able to use the obd2 harness on the obd1 motor, but all you can use from the d16 is the injectors
hondaOchibi7
38
Jan 21, 2011 01:55 PM
pnoyboldstar
Apr 13, 2007 09:13 AM
EKB18BPR3
Apr 4, 2005 03:45 AM
