eg subs?
Old Sep 25, 2007 | 01:21 AM
simplyrob's Avatar
Default eg subs?
finally putting some boom booms in my eg6. having difficulty on choosing how to set my 2 10" subs in the back. ive got s68's and no rear seats. truck boxes for behind the seats or custom make a box to fit in the spare well? how do you eg owners have your subs setup? pics? thanks.
Old Sep 25, 2007 | 07:10 AM
JSPECSIR's Avatar
Default Re: eg subs? (simplyrob)
ive got 1 10 in the tire well. plenty of bass. look in here for pics.
https://honda-tech.com/zerothread/2102462
Old Sep 26, 2007 | 10:17 AM
simplyrob's Avatar
^^^^thanks for the link. nice to see what youve got there.
my friend has this idea to build a box that basically encases the area from the tire well back, filling the vertical space up to where a cargo cover would rest. he wants to mount the speakers facing front and put the amp on the box too. im concerned that this is not only going to weigh a ton, but might get too messy and look crappy.
Old Sep 26, 2007 | 05:10 PM
akunamatta's Avatar
* B A N N E D *
10w7 ftw!
Old Sep 26, 2007 | 05:54 PM
fcm's Avatar
fcm
Old Fart
Default Re: (simplyrob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplyrob &raquo;</TD></TR><TR><TD CLASS="quote">^^^^thanks for the link. nice to see what youve got there.
</TD></TR></TABLE> Tell you friend not to quit his day job, he's not going to make it as a car audio installer.
I don't know of any pr of 10" subs that would need a box with that much volume.
If weight is an issue, fiberglass is your friend, getting the weight of the box and subs as low as possible and as far back as possible is also and advantage, not only for audio performance but for the cars performance also, it helps with weight ratio/balance and center of gravity. 94
Old Sep 26, 2007 | 09:25 PM
simplyrob's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Tell you friend not to quit his day job, he's not going to make it as a car audio installer.
If weight is an issue, fiberglass is your friend, getting the weight of the box and subs as low as possible and as far back as possible is also and advantage, not only for audio performance but for the cars performance also, it helps with weight ratio/balance and center of gravity. 94</TD></TR></TABLE>
thats what i thought. at first i just wanted some truck sub boxes and rest one behind each seat, amp under one of the seats, keepin it easy. then my homie comes over and shoots out this idea. idea itself sounded good but i was skeptical. yeah, that **** would definitely weigh too much. ive spent years trying to lighten my hatch and minimize its weight and now that im there, add 40+ lbs of speaker box? dont think so. truck sub boxes should work yeah? dont you only really need about 1.5 cubic feet of space for 2 10's? these are the ones i picked up, if it helps.
Old Sep 27, 2007 | 05:36 AM
fcm's Avatar
fcm
Old Fart
The sub will work in .6 - 1.5 cuft, [1.2 - 3 cuft for two of them] recommended sealed box is 1 cuft, [2 cuft for two of them].
Again if weight is an issue, they are really the wrong subs, if anything I would use one of them, in a sealed spare tire well box, get your sub as far back in the car as you can.
A couple more thing, your amp is underpowered for two of the subs, they are 300W 4 ohm subs and the amp only makes 1x500W RMS into 4 ohms, [or 2x170W RMS into 4 ohms] and is not stable below 4 ohms when bridged, [but would drive one of the subs without any problem]. 94
Old Sep 27, 2007 | 04:10 PM
JSPECSIR's Avatar
Default Re: (fcm)
yeah deff. go exchange your amp for the kenwood 8103d its rated at 500w rms at 2 ohms. itll do 250 per sub basically.
Old Sep 27, 2007 | 08:25 PM
NSfit's Avatar
Default Re: (JSPECSIR)
My old set up in my eg
maybe it will give you a idea
Old Sep 28, 2007 | 10:07 AM
DrZFiNeSt's Avatar
Default Re: (NScivic)
That setup is nice^
Old Sep 28, 2007 | 10:42 AM
matt360's Avatar
Default Re: (DrZFiNeSt)
keep that amp, build a ported box out of birch ply..you'll end up with around the same amount of output and weight as a sealed box constucted from mdf with more power..
Old Sep 28, 2007 | 01:23 PM
simplyrob's Avatar
^^^^ that **** does look clean man. i fucked around with my hb for about 6 hrs yesterday and have 0% completed. every time i tried to work on something, i hit a dead end. my buddys saws sucked, my front door mounts were from a 4dr, my deck kept blowing fuses, wiring harness all cut and re-soldered, nothing but frustration. for a bit, thought about selling all the **** ive bought and just rockin no stereo like i have for the past 5 years. took a deep breath, thought about it, and will get back at it tonight. the pic above does certainly help. i dont see a bottom part of the box though, looks like he used the actual spare well with some polymer around the edges to seal it? thanks for helping guys.
Old Sep 28, 2007 | 03:14 PM
NSfit's Avatar
yeah there was no bottom. and i did take out the spare to put in this system!. the was sealed so well that if i pushed one sub down the other would come up!
Old Sep 30, 2007 | 06:25 PM
simplyrob's Avatar
spent today messing with my setup. after much frustration this past week, been making progress. got my deck in and working. fabricated/modded some mounts for my front components, and took measurements for my rear box. im gonna try something like whats above, i like that. only gonna use 1 of my subs though. ill have the extra for when i blow the first, lol.
Old Oct 1, 2007 | 08:51 PM
simplyrob's Avatar
NS, sent you a pm concerning your old setup yo.
Old Oct 8, 2007 | 02:38 AM
simplyrob's Avatar
well, heres my almost finished setup. got extra carpet to finish the backseat area. thanks for the idea yo.
Old Oct 10, 2007 | 08:49 AM
JSPECSIR's Avatar
looks nice.
Old Oct 10, 2007 | 03:13 PM
simplyrob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">looks nice.</TD></TR></TABLE>
thanks man, i dremeled the whole thing, took forever. lol. yeah, im totally happy with it. sounds good. been rockin mad luda lately.
noname87
Honda CR-V & Element
12
Jul 14, 2014 04:17 AM
93SiHatchguy
Audio / Security / Video
16
Apr 2, 2012 04:13 PM
eastbay92cx
Nov 26, 2004 09:55 AM
92BlackSi
57
Dec 3, 2003 09:27 PM
