JDM b16 in eg...starts up but after 5 mins dies??? help!!
Old Sep 23, 2007 | 05:47 PM
Jake92eg's Avatar
Default JDM b16 in eg...starts up but after 5 mins dies??? help!!
Hey...my car just started having this problem. New batt and had alt checked today and is fine. Car starts up...runs fine then about 5-6 mins later everything starts getting dimmer untill the car just finely dies, almost like the alt. isnt charging my battery. Everything seems to be in good working order untill it starts loosing juice somewhere...
Anyone else have this problem?? or have an idea on why its doin that?
Old Sep 23, 2007 | 05:57 PM
crazyguy's Avatar
Default Re: JDM b16 in eg...starts up but after 5 mins dies??? help!! (Jake92eg)
there is a white wire from alternator and it is suppose to connect to positive battery terminal. that was what happened to me before..just like your situation
Old Sep 23, 2007 | 06:00 PM
Jake92eg's Avatar
aight. cool thanks, ill go check it out right now!
Old Sep 23, 2007 | 06:09 PM
crazyguy's Avatar
Default Re: (Jake92eg)
cool and keep me posted...and also make sure alternator belt is tight enough..and we have the same car and swap..
Old Sep 23, 2007 | 06:14 PM
Jake92eg's Avatar
Default Re: (crazyguy)
which white wire?...thick one or one of the small ones within the plug?...
Old Sep 23, 2007 | 06:19 PM
crazyguy's Avatar
smaller one with the plug..not the green one..
Old Sep 23, 2007 | 06:26 PM
Jake92eg's Avatar
that white one is suppost to run straight to the postive battary terminal? seems to go in a big black wire loom with whatever else wires are in there...
Old Sep 23, 2007 | 06:30 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jake92eg &raquo;</TD></TR><TR><TD CLASS="quote">that white one is suppost to run straight to the postive battary terminal? seems to go in a big black wire loom with whatever else wires are in there...</TD></TR></TABLE>
huh?? mine goes directly to the positive terminal..and there is no big black wire loom....m...is your b16a obd 1?
hold on..let me go check on mine
Old Sep 23, 2007 | 06:32 PM
Jake92eg's Avatar
Yeah its a obd1 b16a sir2.....k cool.
Old Sep 23, 2007 | 06:35 PM
ihaterust's Avatar
do you have to boost it after it dies?
Old Sep 23, 2007 | 06:37 PM
Jake92eg's Avatar
boost it??
Old Sep 23, 2007 | 06:41 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jake92eg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah its a obd1 b16a sir2.....k cool.</TD></TR></TABLE>
yeah we have the same exact engine and it was my mistake..u are right..those two plugs..the black one and green ones connects to a whole bunch of wires with black plastic cover but it should have one thick single wire that has terminal like the pic shown below that i took 5 mins ago....and is your engine harness come with the engine or ?? uncut?? cause mine harness comes with jdm engine and complete uncut...oem b16a sir II harness
Modified by crazyguy at 8:02 PM 9/23/2007
Old Sep 23, 2007 | 06:46 PM
Jake92eg's Avatar
uh..its an ex harness uncut. not the jdm harness. yeah weird...mine doesnt have one of those goin to the battery. i take a pic for up, hold up a sec...
Old Sep 23, 2007 | 06:53 PM
Jake92eg's Avatar
Old Sep 23, 2007 | 07:03 PM
crazyguy's Avatar
yeah i think u are missing one wire ...are u sure there is no more wire hanging and unconnected under the intake manifold or maybe cut???? cause one thing for sure..your battery is not charged from alternator and your alternator is good...
Modified by crazyguy at 8:23 PM 9/23/2007
Old Sep 23, 2007 | 07:12 PM
HondamanXxX's Avatar
GO GIANTS!
crazyguy knows his **** about these motors. Looks like you are missing that wire for sure. Also, make sure your battery is good to go after this wire is hooked up. Your battery is probably drained.
Old Sep 23, 2007 | 07:27 PM
Jake92eg's Avatar
yeah i'll get under it 2marrow and check around for another wire hangin around. Yeah my battery is on the charger right...brandnew battery too! what if its cut? could i run a wire to the battery from the alternator?...
Old Sep 23, 2007 | 07:33 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jake92eg &raquo;</TD></TR><TR><TD CLASS="quote">yeah i'll get under it 2marrow and check around for another wire hangin around. Yeah my battery is on the charger right...brandnew battery too! what if its cut? could i run a wire to the battery from the alternator?...</TD></TR></TABLE>
no.if it is cut..try to extend it with the proper connector and wire...dont just wire it to alternator directly..
Old Sep 23, 2007 | 07:46 PM
Jake92eg's Avatar
k, im totally hopin it hangin under there somewhere....nothing should be cut at all. thanks for you help 2nite! check back with me 2marrow, ill post weather i find it or not....thanks again
Old Sep 24, 2007 | 04:21 PM
crazyguy's Avatar
bump
Old Sep 25, 2007 | 05:22 AM
crazyguy's Avatar
i am glad your problem is solved..glad that i can help..
Str8JDMCRX
Oct 26, 2010 02:17 PM
Dark_Teg
11
Mar 28, 2009 09:32 PM
red civic standard
Mar 3, 2008 02:34 AM
djsire
19
Jul 30, 2004 12:20 PM
TurboDANDEE
Feb 18, 2003 08:14 AM
