Alternator tested good but not charging
ok so i have a 92 eg hatch i just put the motor back in and everything seemed to be going good till a couple days after the lights and stuff started to dim and my radio shut off, BUT my battery light never came on so i go and try to start the car again and the battery is dead, so i go buy another alternator and a new battery hoping that this would fix the problem but, still nothing i took the battey and both alternators to advance autos to test em and everything was good so i put everything back on again but the **** is still not charging and its makin me crazy, anyone have any ideas? please
Re: Alternator tested good but not charging
1) Unplug the alternator connector and then turn the key to ON(II). Do you measure battery voltage at the Blk/Yel wire terminal in the connector?
2) Is the large white wire connected to the alternator and the hood fuse box clean and tight?
3) What resistance (Ohms) do you measure between the two ends of the white wire?
Speed--Freak
15
01-05-2022 05:22 AM
