....Alternator with SPEEDPRO....
Old Feb 15, 2003 | 10:36 AM
TurboDANDEE's Avatar
Default ....Alternator with SPEEDPRO....
Ok, im having problems with my charging system on my car, my alternator isnt charging. im running a Speedpro and i think i wired it right, but its still not charging. i've even went to the trouble of changing my alternator for a new one, but thats still not the problem. Here's how i have it hooked up...
Black/Yellow wire - Ignition
Blue/White wire - Battery light on the gauge cluster
Thick White wire - Fuse box under the hood
Im running an OBDII alternator and im not running my stock ecu anymore. If can someone help me out and if you see what im doing wrong, please help me out. Thanx.
Old Feb 15, 2003 | 01:31 PM
Default Re: ....Alternator with SPEEDPRO.... (TurboDANDEE)
anyone?
Old Feb 15, 2003 | 10:08 PM
vegan_punk's Avatar
I think I have obd1 but if this helps
black/red- ignition
small white- ignition
thick white- fuse
A guy named Mike hooked my speedpro up. He knows a **** load about them. His user name on here is turbohonda. Talk to him I know he can help.
Old Feb 16, 2003 | 10:46 AM
Default Re: ....Alternator with SPEEDPRO.... (vegan_punk)
thanx man, i will give him a holla.
BUMP
Old Feb 16, 2003 | 08:39 PM
ninesecteg's Avatar
how do you have it setup right now?
Old Feb 16, 2003 | 10:00 PM
vegan_punk's Avatar
TurboDandee is there 2 wires that you have going from the plug in the alternator to where the thick white wire is? I was having the same problem but then Mike had me switch those two wires to 12v+ when the key is turned.
Old Feb 17, 2003 | 06:44 AM
Default Re: ....Alternator with SPEEDPRO.... (ninesecteg)
Old Feb 17, 2003 | 06:46 AM
The only 2 wires im using from the plug is the black/yellow and white/blue. black/yellow is hooked up to ignition, white/blue is hooked up to the battery light. maybe i need to give that blue/white ignition also?
Old Feb 17, 2003 | 08:22 AM
littlebluecrx's Avatar
My question for is, does your battery light turn on when you just apply the ignition, power before you start the car?the wht/blu wire goes to the electric load detector in the fuse box.It has to be run to the dash, the altenator fuse has to still be in the dash. You can take a light bulb, and put it in series with the wht/blu wire, then ground it. The blk/yllw should get 12 volt power, this should make the altenator charge, it is temporary fix, but this should make it charge. If I did not have 30 inches of snow , I could get to the shop, and tell you for sure, this was all of the top of my head. Jason
Old Feb 17, 2003 | 08:26 AM
Default Re: ....Alternator with SPEEDPRO.... (littlebluecrx)
You know what, my battery light is not turning on when i put it on the "on" position. did i hook up the white/blue wire wrong? all the fuse is still on the factory location cause i never messed with them and i did check if its blown, still good.
For temporary use.. hook up a light to the white/blue wire and ground it?
Old Feb 17, 2003 | 09:30 AM
vegan_punk's Avatar
I would try blue/white to ignition and see if it works?
Old Feb 17, 2003 | 11:54 AM
Yes, but put a load between it and ground, like a light bulb, it is normal tied into the dash battery, light, and the electric load detector., do not tie it to positive power source, it will harm the altenator.
Good luck. Jason
Old Feb 17, 2003 | 12:36 PM
bambooluv's Avatar
Thanx guys, I got it to work!
I tried every little advice that i got, but still no luck. I finally decided to take apart my harness and do it all over. Turned out that the power wire to the alternator was not hooked up (solder came apart). So, patched that up and slapped it back on the motor. Turned on the key, battery light came on, fired it up and battery light turned off. Checked the voltage on the alternator and its a solid 14v+. Thanx again for those who gave me some helpfull tips. Peace out!
-Dandee (im using my friend's sn)
[Modified by bambooluv, 8:36 PM 2/17/2003]
Old Feb 17, 2003 | 01:04 PM
CHEETAH's Avatar
Default Re: ....Alternator with SPEEDPRO.... (bambooluv)
the white blue/white wire (facing back of alt plug its top right) needs +12v to begin charging ...
hook it up +12v swi ign source.
greg
[Modified by CHEETAH, 10:04 PM 2/17/2003]
Old Feb 17, 2003 | 01:24 PM
bambooluv's Avatar
Default Re: ....Alternator with SPEEDPRO.... (CHEETAH)
thnx guys problem solved one of the wires decided to fry itself and the connection on one of the wires broke lose.All gravy now thnx-pdang
Old Feb 17, 2003 | 01:53 PM
MotorMatrix.com's Avatar
I am a bad person
No motec after all?? or was this speedpro not on your car??
Old Feb 17, 2003 | 02:14 PM
bambooluv's Avatar
Default Re: ....Alternator with SPEEDPRO.... (MotorMatrix.com)
yeah this is for dandee's car. I just picked up my new motec system from tony saturday.-pdang
How goes your car Mike?
Old Feb 17, 2003 | 08:04 PM
I am a bad person
waiting on pauter rods so i can put it back together. i ordered a speedpro today and 1600cc injectors. the car is getting a roll cage as we speak. I'm shooting for the end of the month to have it back up and running.
Old Feb 17, 2003 | 08:13 PM
bambooluv's Avatar
hehe yeah im also waiting on my pauter rods,and i gotta wire it all up and get the suspension on.long way to go for me maybe amonth or so as well.-pdang
Old Feb 17, 2003 | 08:15 PM
boostaholic's Avatar
Glad you got it working Dan. I told you that yellow/black wire probably wasn't getting a 12v power source when kicked on. Are you back in houston yet?
Old Feb 18, 2003 | 07:33 AM
Default Re: ....Alternator with SPEEDPRO.... (boostaholic)
Ya man, got back last monday. I have about 45 miles on the car and gotta finish breaking it in before i dyno. so far so good, except my idle is real high, bounces up and down between 2500-3000 rpm and running lean on bottom end. anyone know where i can adjust this?
Old Feb 18, 2003 | 07:51 AM
How's your a/f at idle? What RPM do you have cloosed loop enabled? What's your rpm vs. coolant temp graph look like? Check for any vacuum leaks. If it's running lean, do a couple runs and see where on the base VE chart it's leaning out and add some fuel there.
Old Feb 18, 2003 | 08:14 AM
A/F - reads around 14-16
Closed loop - enabled on 500 high and 400 low RPM
RPM vs. Coolant temp. - 1300 rpm to 84 deg. then dips down to 1000 rpm to 140 deg.
I will try adjusting the base VE charts and add some fuel on the bottom end. right now it sits around 38-44 below boost and before 3000 rpm.
Str8JDMCRX
Oct 26, 2010 02:17 PM
Dark_Teg
11
Mar 28, 2009 09:32 PM
Cone Assassin
Dec 13, 2007 03:12 PM
kuja
Sep 1, 2005 09:52 PM
TurboDANDEE
Feb 16, 2003 10:52 AM
