Cmplete turbo setup,motor,trans for sale as a package!
I have a long list of parts!This is a complete setup in a running car. Come see the setup and go for a ride! You will love it and definately wont be disappointed!
Ok here we go!
Motor:
A 1.6l J-Spec Dohc ZC- 750.00
OBD1 distributor-200.00
Energy suspention motor mount inserts
Walbro 255 Fuel Pump-100.00
New Timing Belt
Trans:
SI 5 speed-200.00
7.5lb flywheel-100.00
6 puck sprung clutch-200.00
Turbo Setup:
Garrett T3T04b 50 trim-795.00 w/ wg
Tial 38mm wg(10lb spring)
Turbo XS BOV-150.00
Stainless mini ram manifold( No Cracks)400.00
3" DP-150.00
Slash Cut ventilation system for Crankcase Ventilation-50.00
3" exhaust with moroso spiral flow and 3" flex section-150.00
27.5X10.5X3" intercooler made by KaizenSpeed-200.00
2.5" Charge piping Fabricated by Kaizenspeed-150.00
Electronics/Electrical:
PLX Wideband-250.00
ECU tuned on CromePro tuned by Kaizenspeed-400.00 w/ecu
OBD0 to OBD1 jumper harness-100.00
7600 rev limiter w/ no speed limiter
I am forgetting a ton of things but the total is over 4000.00 not including the 1600.00 in labor from Kaizenspeed! If you have questions you can call reid at Kaizenspeed 509-585-0900 and ask him about Donovan's turbo setup!
This is literally everything you need to directly drop in your car and have a hard running street car! The car is very fast and super reliable! The motor has only been on full synthetic since day one! When it gets traction the car destroys sti's, evo's etc. Drop this in your car with the ecu and your car will run flawless! My engine harness is included! I can email pictures if needed but better seen in person and you can go for a ride! 2500.00 firm with motor,trans,turbo setup, ecu with full tune! Everything! Call me with questions Donovan 541-571-4395
Ok here we go!
Motor:
New Timing Belt
Trans:
SI 5 speed-200.00
Turbo Setup:
Turbo XS BOV-150.00
3" DP-150.00
PLX Wideband-250.00
mr_hahn73
Northwest (Sales)
Sep 25, 2007 05:08 PM
