my 97+ prelude wont start cold?
Old Sep 22, 2007 | 02:41 PM
dustin_bb6's Avatar
Default my 97+ prelude wont start cold?
i have a 1997 type sh and it has a little problem starting when it's cold, 50*f or less. i've changed my distributor, cap, rotor, plugs, wires, coil 2 times, control module 2 times, ect, and it isnt pulling a code. I know it's a ignition problem im just having a hard time locating it. So if there is anyone who has an idea please reply.
Old Oct 15, 2007 | 02:30 PM
dustin_bb6's Avatar
Default Re: my 97+ prelude wont start cold? (dustin_bb6)
does anyone know what is going on with my ride??? or is everyone just as clueless as i am???
Old Oct 15, 2007 | 03:41 PM
vinuneuro's Avatar
Have you tested the battery?
Old Oct 15, 2007 | 05:08 PM
mattsnooz's Avatar
Default Re: my 97+ prelude wont start cold? (vinuneuro)
yeah. Most people don't know but your battery should get replace once every 2-3 years sometimes (depending on battery) Its 120$ or so dollars but no matter what happens it should still improve starting somewhat. It could be a multitude of other things in the starter circuit
Oh to help I'm told that if the cranking is slow and weak its probably the battery or alternator. So maybe listen to the cranking.
Old Oct 15, 2007 | 06:27 PM
lude98SH's Avatar
Default Re: my 97+ prelude wont start cold? (mattsnooz)
Idk if its different in different parts of the country due to climate. But here in SE pa batteries generally last 5 years anymore. Or they should. Its not unheard of however for them to go alot sooner.
If the problem is only happening when its cold out. I would first check the battery and alternator. Othewise it may be a mixture problem. It is harder to start a cold engine. The fuel, intake manifold and cylinder are all cold. When you first start the car it will enrich the mixture. Fuel will condense in the intake manifold and on the cylinder walls and fall out of suspension. Basically your throwing a **** load of fuel at the engine and hoping it burns some, enough to start the engine. This is why cars have higher emissions when cold. All the fuel that puddles in the IM and on the cylinder walls is just pushed right out the exhaust. This is also the reason when you do obd1 emissions tests ( low load dyno test with sniffer here in phila suburbs) the car must be warm. The car will at this point be in open loop running on predetermined fuel maps. And doesnt even look at the o2 sensor until the engine goes into closed loop.
Old Oct 18, 2007 | 11:02 AM
dustin_bb6's Avatar
i changed the battery because i thought that was the problem too but it wasn't.... and i know it isn't a fuel problem because i checked for spark and there wasn't but when it gets warm.... BAM it starts and everything is fine.. and there is no CEL...
Old Oct 18, 2007 | 04:34 PM
ConanDan's Avatar
Default Re: (dustin_bb6)
try re-seating your rotor and dis cap. really to me sounds like some kind of electical problem... did you make sure that you set your spark plugs to the correct distance?
Old Oct 19, 2007 | 08:49 AM
dustin_bb6's Avatar
nope not the problem because it isnt getting spark out of the coil....... it has power to the coil but nothing coming out?????
Old Oct 28, 2014 | 03:59 PM
Rfox350's Avatar
Did anyone ever figure this problem out? My 97 lude is having the same exact issue.
Old Oct 28, 2014 | 04:08 PM
nemesis25's Avatar
Replace your spark plugs and try running a new ground from the negative terminal to the valve cover.
Old Oct 28, 2014 | 04:09 PM
nemesis25's Avatar
Then, you may have a bad ignition coil. Or a bad ignition switch.
Old Oct 28, 2014 | 04:22 PM
Rfox350's Avatar
Plugs and ignition switch is new, I will check out the ignition coil
slow4dr23
Feb 17, 2014 12:15 PM
silentkid
Mar 3, 2010 11:59 AM
DOHC4VTEC
Jan 23, 2007 04:26 PM
Sticky Tires
Feb 12, 2003 01:18 AM
Chicotrini
May 27, 2002 01:15 PM
