D15b ENGINE SWAP..??
Old Sep 22, 2007 | 09:03 AM
TeCTaK's Avatar
Default D15b ENGINE SWAP..??
Have a Honda Civic VTi 92' D15b SOHC VTEC...
Was originally going to drop in an H22a7 out of EURO R but instead dropped into Si Integra....
Wondering what would be easiest, best and most affordable engine to drop into VTi?? Prefer good torque and healthy top end...
No B-H-F Series conversion for this car... Something cheap.. And suggestions on where I can get some good FAQs for whatever conversion...
Thanx....
Old Sep 22, 2007 | 09:07 AM
Ron454321's Avatar
Default Re: D15b ENGINE SWAP..?? (TeCTaK)
The only swap that would be cheap would be comparable to what you have now. D series engines is what is cheap, and you don't want B which is practically the next step up. That D15B should run you about 130 HP, don't see how you can get more than that whithout going OBD-II D-series
Old Sep 22, 2007 | 09:17 AM
TeCTaK's Avatar
What bowt ZC? They good engines SOHC and DOHC but power to weight? much difference in weight with ef hatch and eg sedan?
Old Sep 22, 2007 | 09:19 AM
BlackoutVTi's Avatar
Default Re: D15b ENGINE SWAP..?? (Ron454321)
Yeah, D15B is about the best in what you're looking for. A little more displacement would be given by the D16Z6, which may yield a fraction more all around torque than the D15B, but not enough I think, to be noticeable. If you want to keep it D series, and want some more all around torque and response, without trying to be too fast, you could always just rebuild the D you have, and get a good, mild supercharger setup. (that was a lot of commas, but you know what I'm saying) You could also go for a mild turbo kit.
Old Sep 22, 2007 | 09:27 AM
Ron454321's Avatar
The ZC SOHC will either come in a VTEC or non VTEC model, VTEC model being comparable to a D16Z6. Yes the hatch will weigh less, for a good comparison there is a post someone made that gives the weights, just search it real quick.
Old Sep 22, 2007 | 09:28 AM
TeCTaK's Avatar
B18c1 much trouble to drop in this car?? how much money would I have to spend to get parts 4 swap? mounts ecu etc?
Old Sep 22, 2007 | 09:30 AM
97Ej6mike's Avatar
Have you thought about Forced induction on the D15?
Old Sep 22, 2007 | 09:40 AM
TeCTaK's Avatar
No... Only on my H-Series, I'll post a thread for that later.. This project for my girlfriend don't want her to psi off the road.. lolz..Cheers anyway
Old Sep 22, 2007 | 09:44 AM
Ron454321's Avatar
I'm not sure where you are located, I'm guessing Europe (Damn my geography skills), but you would have to source a motor out there, I wouldn't wanna have one shipped from here that would cost more than the engine itself. The parts needed for the swap are pretty easy and usually you can get everything in a package deal like from Hasport.
Old Sep 22, 2007 | 09:45 AM
Default Re: (TeCTaK)
Oh I see. Well, what about a good rebuild with a nice mild cam, some of the stereotypical boltons, and a tune? That ought to give a good bit of torque for your gf's daily driver. I'm just trying to save you the trouble of having to get another engine brought in.
Old Sep 22, 2007 | 09:52 AM
TeCTaK's Avatar
Yeah thats perfect! What's a good mild cam?
Old Sep 22, 2007 | 09:54 AM
97Ej6mike's Avatar
Location Hamilton, NZ
New Zealand?
Old Sep 22, 2007 | 09:57 AM
Ron454321's Avatar
It only said Hamilton when I looked before, I have a Hamilton here in Baltimore but people dont talk like he does.
Old Sep 22, 2007 | 10:06 AM
Default Re: (Ron454321)
I would say look into Skunk2, and it'd be recommended to upgrade the valvetrain, but that's kind of good anyway if you intend to rebuild. I say that it'd be your best bet to do some research on that option.
Old Sep 25, 2007 | 07:22 AM
screaminj's Avatar
Default Re: Swap
I plan on dropping a D15B into my 92 CX hatch. And this company in Virginia is selling the following items to me for 800 bucks.
D15B VTEC Engine
5 speed Transmission
ECU (PO8)
Wiring harness OBD1
Distributor / Exhaust Manifold / Intake Manifold
Down pipe / Fuel Rail / Alternator
Injectors / Sensors / Starter
Throttle Body
Are they all I need? Or do i have to buy more parts for the swap? Will this be a direct drop-in, bolt-on swap? Am i able to use my CX stock axles? I've never a done a swap before, i really would like to do it myself, even though it'll take much time. My CX is should be OBD1, right? Will I be able to install power steering? If you have information, please help me, thank you!
Old Sep 25, 2007 | 07:27 AM
screaminj's Avatar
Hey Ron454321, do you know any good source here in Maryland area where i can get JDM engines, parts, etc? Do you know anyone reputable? Do you have any pictures of your CX? What kind of swap do you have? Let me know, please. Thanks
Old Sep 25, 2007 | 08:41 AM
Ron454321's Avatar
I have just a SOHC ZC VTEC motor. I'll post a link up in a few minutes for pictures. I don't really know the shops around hereto well but to buy a swap I would try Noyan USA in Northern Virginia. They are realy nice down there and you skip having to pay for shipping, plus you get to chose which engine you want out of the lot. I get most of my parts online though.
MANDO6669
41
Apr 2, 2006 12:34 PM
DaMmniTz
Jan 6, 2005 02:22 PM
hybridzOr
Feb 24, 2003 04:34 AM
